#1 |
i need your help again. i fixed the tps wiring and the tps is working perfect (as you will see in the video it shows how much throttle is open in volts).
itis a bone stock 1987 7mgte motor. there is a hesitation, stumble, hiccup at around 2500 rpm. it is running very rich and getting horriable milage. if it is a cold motor it runs good for about 40 seconds then this stumble starts. i have an inline walbro and a intank OE supra pump. while driving it can rev above the biccup but if the throttle is barely cracked it accels like i am flooring it. when the speed catches up to how much the throttle is open it acts like there is a dead spot. and the throttle is like a switch between on or off. if i rev it up and hold it at like 4k and let it off it revs down and almost dies or dies. most i have boosted on that crap gauge is 4psi. io have great vacuum. video HELP http://www.youtube.com/watch?v=vOdnP...ature=youtu.be |
Thread Tools | |
Display Modes | |
help 7mgte | graywolf1969 | MKIII Supra | 8 | 03-13-2011 09:34 PM |
7MGTE to 7MGE | karu | MKIII Supra | 4 | 10-22-2010 07:22 AM |
7mgte to 7mge conversion help | wayzhack | MKIII Supra | 7 | 09-07-2010 08:22 PM |
Need help please. 7mgte | Toyota1 | MKIII Supra | 4 | 05-22-2010 08:33 AM |
7mgte and 7mge question | supraman121 | MKIII Supra | 2 | 01-12-2007 09:09 PM |
