Old 11-19-2012, 03:22 PM   #11
907mge
907mge's Avatar
Yes with will fitment proper offset is everything. My friend is running a 17x9.5 in the rear with a 2754017 tire which doesn't rub with his h and r springs. If you are rubbing with a 225 you need a different wheel. Changing things like offset and overall wheel diameter can have negative effect on handling and suspension geometry.
Installing New Tires w/ Bad Rack & Pinion? sd88supra MKIII Supra 3 06-15-2012 05:35 PM
New Tires! 97SupraTT Non-Generation Specific Questions 0 10-03-2009 01:11 PM
Has anyone purchased tires from these sites? Chambers MKIII Supra 7 08-16-2007 03:27 AM
Tires And Rims! teedoff00 MKIII Supra 1 11-30-2006 11:47 PM
New Tires scruffboy Non-Generation Specific Questions 3 12-08-2005 12:39 AM
