Old 11-29-2012, 10:30 AM   #1
MX83
MX83 is on a distinguished road
Smile 7MGE toyota CRESSIDA question need help asap
whats up! well i just got a 7mge 1992 toyota cressida from my dad (which is BEAST btw) but it needs a new belt... from what i see its the lowest belt by the power steering pump.... im not use to to the 7m engine design being a honda head lol but my question is does the 92 7mGE motor have 3 different belts or 1 serpentine belt? i just cant tell... and if so. what are the EXACT NAMES and LOCATION or atleast part numbers.... I need to fix this beauty soon.. 1992 cressida with only 49,000 miles..thanks so much guys
MX83 is offline   Reply With Quote
Old 11-29-2012, 08:51 PM   #2
The timing belt *SHOULD* have a cover over it. You can't see it normally. It's the only belt with axial teeth, about 1 1/4" wide.
Old 11-30-2012, 02:21 AM   #3
btwilson86
Super Moderator
btwilson86's Avatar
The engine has 3 belts for the accessories (not 1 serpentine belt). One for the Alternator and Water Pump, one for the A/C and Tensioner, and one for the Power Steering Pump.
IIRC, the power steering belt is the closest to the radiator, then the A/C belt, then the Alternator belt. There are 3 different belt locations on the harmonic balancer.
Question about swapping from a 7MGE to a 1JZGTE Supraman24 MKIII Supra 13 08-23-2009 10:25 PM
Retorque 7mge & 7mgte question SilenceboneSupra MKIII Supra 2 01-30-2008 10:17 PM
Toyota Supra Engine Question l_o_t_s_r MKIV Supra 33 08-30-2007 02:29 AM
