Old 12-28-2012, 08:41 PM   #1
Blindedlegacy
Blindedlegacy is on a distinguished road
Default Cylinder head teardown question
can someone tell me what in the world this is. on the left is the bucket for the valve and the ring was under the bucket. not every bucket had this and keep in mind i didnt even remove the valves yet
http://sphotos-a.xx.fbcdn.net/hphoto...20671799_n.jpg
Blindedlegacy is offline   Reply With Quote
Old 12-28-2012, 10:51 PM   #2
interested!
Question Cylinder head teardown question
Hi! - Questions : Can you let us know what engine this refers to ? ,How long has this engine been running like this ? what the rings made of ? , and are the rings the same width ? .
Old 12-28-2012, 10:58 PM   #3
Blindedlegacy
Originally Posted by interested! View Post
Hi! - can you let us know what engine this refers to ? , and what the ring is made of?
7mge, and its a thick metal. really like a thick washer and im in the process of rebuilding. they are all the same size and everything
Old 12-28-2012, 11:08 PM   #4
interested!
Default cylinder head teardown question
Hi again , I found this on the Mk3 TRSM website for the 7M-GE:
http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=32
This looks like a shim ? , not sure , only worked on my 7MGTE , hope it helps . The adjusting shims should be between the cam and top of the bucket , never seen these rings on any engine before .
See : http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=10 for position .
Old 12-28-2012, 11:14 PM   #5
Blindedlegacy
ive been looking at this for awhile. the shims are on top of the bucket. and there is nothing on this page that suggest what this is
Old 12-28-2012, 11:32 PM   #6
interested!
Question cylinder head question
I'm lost ! do you think the previous owner put them there ? cannot think of any reason for them , Question? out of interest ? -why are you overhauling the head ? .
Old 12-29-2012, 12:35 AM   #7
907mge
907mge's Avatar
http://www.cygnusx1.net/Supra/Librar...spx?F=1302&P=1
Those are the washers for the head bolts.
Old 12-29-2012, 04:10 AM   #8
Yup! Man, if I had a nickel for every time I found those just shoved in some other location by an ignorant owner/mechanic.... well, I'd have about $.50 but nonetheless that's $.50 too much.
Old 12-29-2012, 03:09 PM   #9
Blindedlegacy
OMFG WOW lol i did not even think this kid before me got this far in effing up my car. unplugged sensors, cut wires and bad wiring, removing the brackets to remove the engine (real pain getting it out the way i did) you think that made a different in performance??
Old 12-29-2012, 03:12 PM   #10
Blindedlegacy
Im rebuilding the bottom end because of spun rod bearing, shown in the link at the bottom, and im getting everything cleaned and resurfaced and going most of the work brings the price down
http://sphotos-b.xx.fbcdn.net/hphoto...71787646_n.jpg
Tags
rebuild, spacer, valve
Cylinder head casting number Sonyps307 MKIII Supra 5 01-18-2012 08:04 PM
ticking noise from head cylinder one exhaust side night-rider MKIII Supra 8 06-14-2011 06:35 PM
stupied question on head removal suprabahamut MKIII Supra 18 07-02-2007 12:47 AM
torque settings for big end shells and cylinder head johnkarl MKIII Supra 4 11-03-2006 04:01 PM
Cylinder Head?? ZauggIt1 MKIII Supra 8 10-24-2006 01:51 AM
