Old 01-10-2013, 04:47 PM   #1
SupraHead
SupraHead is on a distinguished road
Default Toyota Supra Reverse Stuck
Hey guys i have a problem where i try to put my gear into reverse but it gets stuck, so then i have to put it back to neutral and keep trying to shift it into reverse, its like sometimes theres a wall and wont let me, is there something wrong with my clutch?
SupraHead is offline   Reply With Quote
Old 01-18-2013, 01:44 AM   #2
supraheelfan
supraheelfan's Avatar
supraheelfan is on a distinguished road
mine does that too sometimes; some info would be beneficial. But seeing as how the tranny and clutch are over 20 yrs old, I'm not complaining about a little hard shifting.
Anyone who has never made a mistake has never tried anything new.
supraheelfan is offline   Reply With Quote
Old 01-18-2013, 10:56 AM   #3
ianstaley
ianstaley's Avatar
ianstaley is on a distinguished road
More likely the selector fork's are wearing in the synchro although I don't think reverse is synchronised. So take a look at the selector forks.
Bored old git that loves his toyota's I have two one a Supra MK3 with a targa top the other is a brit Camry V6.
ianstaley is offline   Reply With Quote
Old 01-18-2013, 10:11 PM   #4
Before you go pulling the big stuff apart check that the slave cylinder is moving far enough, the clutch master cylinder's reservoir is full, and that the fork isn't bent. Flushing the transmission fluid may also aid in the ease of shifting but the impact on shifting into reverse is seldom significant... worth a try though.
Old 01-23-2013, 09:11 PM   #5
pandrade
mine does the same, my way around it is to shift from neutral into 3rd and then reverse. actualy all of my toyotas that i have owned have the same issue whith reverse, eather they dont like going there directly or when they do they like to grind, i put some synthetic gera oil in the ol box and that helped quite a bit but not perfect( doesent help the tranny has 135k miles on it)
also what cre says is big too, i replaced my clutch cylinder, slave and i put in a stainless steel braided clutch line and PROPERLY adjusted the clutch free play and it made the problem more or less go away but it will occasionly eather wont go in easy or grind( new clutch and pressure plate too) i think its just a small over sight by toyota
Have you ever experienced someone SupraHead MKIII Supra 8 10-30-2010 04:06 AM
Clutch kit for a 1993 JDM Toyota Supra SpRuCe Non-Generation Specific Questions 0 04-13-2009 10:20 PM
Toyota Supra Engine Question l_o_t_s_r MKIV Supra 33 08-30-2007 02:29 AM
new motor west_side_supra MKIII Supra 38 04-12-2007 10:11 PM
