#1 |
mine does the same, my way around it is to shift from neutral into 3rd and then reverse. actualy all of my toyotas that i have owned have the same issue whith reverse, eather they dont like going there directly or when they do they like to grind, i put some synthetic gera oil in the ol box and that helped quite a bit but not perfect( doesent help the tranny has 135k miles on it)
also what cre says is big too, i replaced my clutch cylinder, slave and i put in a stainless steel braided clutch line and PROPERLY adjusted the clutch free play and it made the problem more or less go away but it will occasionly eather wont go in easy or grind( new clutch and pressure plate too) i think its just a small over sight by toyota
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come Last edited by pandrade; 01-23-2013 at 09:13 PM. |
Have you ever experienced someone | SupraHead | MKIII Supra | 8 | 10-30-2010 04:06 AM |
Clutch kit for a 1993 JDM Toyota Supra | SpRuCe | Non-Generation Specific Questions | 0 | 04-13-2009 10:20 PM |
HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
Toyota Supra Engine Question | l_o_t_s_r | MKIV Supra | 33 | 08-30-2007 02:29 AM |
new motor | west_side_supra | MKIII Supra | 38 | 04-12-2007 10:11 PM |
