-   -   throttle pos sensor (http://www.toyota-supra.info/forums/mkiii-supra/20879-throttle-pos-sensor.html)
DSMeATER 01-21-2013 03:04 AM
throttle pos sensor
okay, so I put in a new throttle positioning sensor today (what a pain in the ass that was) thinking that would solve all my problems...but it was really on the contrary now when the car did fire it had a high followed by a bouncing idle ... now it wont fire any ideas on what could be causing this issue?
DSMeATER 01-21-2013 03:06 AM
also forgot to mention that I put in a new harmonic balancer yesterday just in case that could cause any of this
Travis89Turbo 01-21-2013 08:05 PM
Did you adjust the tps when you installed it? If not that may be your problem, also possibly vacuum leak based off the bouncing throttle. Maybe a stuck IACV.
Start with adjusting the TPS per TSRM.
What was the problem you were trying to solve to begin with??
DSMeATER 01-29-2013 11:57 PM
well the car wasn't holding idle then also when I step on it in any gear higher than first after 3000 rpm it causes my engine to cut out kinda like its being limited... camshaft pos sensor maybe?
