okay, so I put in a new throttle positioning sensor today (what a pain in the ass that was) thinking that would solve all my problems...but it was really on the contrary now when the car did fire it had a high followed by a bouncing idle ... now it wont fire any ideas on what could be causing this issue?
87 supra targa t3/t4 swap 14psi, hks ssqv3, e- cutout |
#3 | |
![]() Quote:
Start with adjusting the TPS per TSRM. What was the problem you were trying to solve to begin with??
1995 Toyota Supra SE 71k miles. Master power T70 stock 2jzge 1989 Toyota Supra. 1jzgte swap 5 speed of course.. Driftmotion 60-1 single turbo kit. Cxracing FMIC. 2jz 550cc injectors... soon to come..... EMS Stinger. BC 264 cams 680cc injectors Spec stage 4 clutch and A LOT of boost!------SOLD 1999 Ford F350 diesel 2004 Jaguar XJR Supercharged If it hasnt broke you haven pushed it hard enough!! |
well the car wasn't holding idle then also when I step on it in any gear higher than first after 3000 rpm it causes my engine to cut out kinda like its being limited... camshaft pos sensor maybe?
Throttle Position Sensor | Jay633 | MKIII Supra | 3 | 01-19-2012 05:34 AM |
Throttle Position Sensor | Dan Swanson | MKIII Supra | 0 | 08-22-2009 01:58 PM |
throttle postioing sensor | Jeff_5_7 | MKIII Supra | 3 | 09-10-2007 10:36 AM |
throttle position sensor | 88turbo1 | MKIII Supra | 6 | 09-24-2005 04:51 PM |
SUB THROTTLE POSITION SENSOR BYPASS | TRICIA93TT | MKIV Supra | 0 | 08-26-2005 03:31 AM |
