Old 02-20-2013, 12:57 AM   #1
rcs666
rcs666 is on a distinguished road
Default need help with my 88 supra, non turbo
Maybe you guys can shed some light on this situation. I bought an 88 supra last week. For way cheap. It was running, but had some obvious issues, such as needing paint, a windshield, the starter is going out (but still works after a few tries).
Now heres the issue. It ran when i bought it. It ran a liitle rought, and i was told it was due to needing new plugs and wires. So i drove it home (maybe 45 mins), and went to do the plugs. I had to pull the throttle body due to it covering 2 plugs, and cleaned it while it was off.
When i went to do the plugs though, there was probly about a good inch of what looked like oil and coolant mix on top of the plugs. When i removed the old plugs this all drained into the cylinders. I replaced the plugs and wires, reassembled everything, and fired it up. I ran it for probly 5 minutes, and it was running way better.
So after 5 minutes of running it, i shut it off to replace the clamps on a hose, and tried to start it again. Only this time it wont start. The battery is fine, it has gas, and everything is put back together correctly.
So WTF? why wont this thing start?
rcs666 is offline   Reply With Quote
Old 02-20-2013, 01:28 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Oil on the spark plugs is fairly common with the MKIII's, you can check out the threads in the FAQ on how to diagnose/fix that. I would be concerned about the possibility of coolant on top of the plugs (although that could just be from a leaking hose, like the 2 that run to/from the throttle body).
In short, there's not enough info here to determine why your car isn't running. Are there any CEL (Check Engine Light) codes stored? How does your wiring look? Are there broken wires/connectors, anything unplugged, anything loose?
When you say it won't start, do you mean the starter doesn't spin? Or does the engine turn over but not fire? Or does the engine turn over, sputters, but doesn't run on it's own?
Old 02-20-2013, 01:37 AM   #3
rcs666
Its turning over, but not firing. Could it be flooded?
Old 02-20-2013, 01:52 AM   #4
btwilson86
Super Moderator
btwilson86's Avatar
See above for my follow-up questions.
Old 02-20-2013, 01:56 AM   #5
rcs666
The check engine light is on, cant get the codes checked because it wont start now. Ive double checked all the wiring and hoses, and everything appears fine.
Old 02-20-2013, 01:59 AM   #6
btwilson86
Super Moderator
btwilson86's Avatar
The car should not be running when checking codes (the key is in the "on" position, but you don't actually start the car). Check the codes as outlined in the FAQ and post back here.
Yes, there is a possibility it could be flooded (although unlikely).
If the car has sat for over an hour since you last tried starting it, you could go and try again. If it starts, then great. However, you should still check the codes because if the light is on, then there is a problem that should be addressed and any other troubleshooting would be pointless without knowing what the computer is trying to tell you.
Old 02-20-2013, 02:58 AM   #7
If there was a lot of oil then you've probably fouled the new plugs already. Pull the plugs, clean them thoroughly with gasoline and a soft brush. Let them dry. Reinstall, start the car and run it at about 1500-2000RPM for a a couple minutes to flush all that oil and carbon out.
Old 02-21-2013, 02:33 AM   #8
rcs666
The plugs where totally the issue. I just bought new ones because i didnt feel like cleaning the old ones, and it fired right up. It smoked a little and had trouble idling at first, but seems to be running great now. Now to tackle the starter, windshield, and paint!!!
89 supra turbo targa top 500hp all new mods! Little rock, ar marcmann982 Buy/Sell Cars 3 12-15-2011 10:52 PM
*SOLD* - 1994 Toyota Supra Twin Turbo - 2JZ-GTE 6spM - RARE!!! SupraPhan Buy/Sell Cars 3 11-24-2009 04:15 AM
how easy/diff. and what's involved in droppin turbo in 87 supra na the t3d MKIII Supra 2 09-14-2006 05:16 PM
