Old 03-11-2013, 01:55 AM   #1
dwthomas42
dwthomas42 is on a distinguished road
Default 7mgte map ecu 3?
so im looking to loser my restricting afm and get a map ecu. i friend has one for sale its the map ecu 3. i've search for the past couple of days and have been trying to find a wiring diagram or opinions from someone already using a map 3 ecu.
dwthomas42 is offline   Reply With Quote
Old 03-12-2013, 06:03 AM   #2
The 7M-GTE's KVAFM isn't very restrictive at all until you start getting into some of the significantly larger turbos. A fuel controller and better intercooler may be a better use of your money.
Anyway, I haven't heard anything about the v3 on the 7M but I really hope it's less finicky than the v2 was. A lot of people found it to be a major headache. Wiring should be very simple, probably similar to the MAFT Pro's wiring.
Old 03-13-2013, 10:35 PM   #3
dwthomas42
Well I'm going big turbo and my afm code came up a few days ago. The little bit I have heard about it is that it is a lot better.
Old 03-15-2013, 04:40 AM   #4
Looking around a bit it seems to get the same feedback as the earlier versions and the MAFT Pro (which I have a lot of personal experience with). A lot of people feel it temperamental and tough to get running smoothly, would go with a standalone if they had to do it over again, think the learning curve was too steep and ended up paying a shop to tune it all... You see the same complaints for anyone running any number of piggybacks though, in this case they're all just rolled into one unit. If the '3' is easier to tune and has a simpler learning cure then have at it. If not you might want to learn on something which isn't going to cripple your car while you figure it out.
Need help please. 7mgte Toyota1 MKIII Supra 4 05-22-2010 08:33 AM
Twin turbo on 7mgte? supraman121 MKIII Supra 7 08-24-2007 02:12 PM
7mgte front clip supraman121 MKIII Supra 4 05-31-2007 01:27 PM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
