Old 03-12-2013, 03:28 AM   #1
Sonyps307
Default 7mge knock sensor rewire not working code 52
Ok so I have a rebuilt 7mge and I rewired the ks 3 times and tried different knock sensors. Today I rewired it again with a new wire and ks connector also a new ks from Toyota. I followed this ks rewire guide. i also swapped ecu still have code 52.
http://www.turboninjas.com/supra/knocksensor_rewire.pdf
Old 03-12-2013, 05:56 AM   #2
Are these new or used sensors? They're VERY delicate devices and it's not unheard of to end up swapping out a handful of used sensors before you find a good one. I don't know if the thread is the same but in the MR-2 and Celica communities they've taken to using an adapter to swap in inexpensive GM knock sensors with the S series engines (5S and 3S, specifically). You might look into it and see if it'll work on the 7M.
Given that the knock sensor is a piezo electric device an abnormal knock or rattle may cause a signal to be sent to the ECU which is causing the ECU to think there's an abnormality in the circuit.
That's all I've got as far as suggestions.
How to check diagnostic codes suprra_girl MKIII FAQ 10 12-27-2011 08:30 PM
how to do a diagnostic suprra_girl Supra FAQ 40 12-27-2011 08:26 PM
code 52 knock sensor re-wire done STR MKIII Supra 0 06-08-2011 03:17 AM
code 52 knock sensor can't pass emissions hotrod705 Non-Generation Specific Questions 12 08-18-2009 07:44 AM
Code 52 Knock Sensor....Help..Please SupraManFan Non-Generation Specific Questions 1 10-10-2007 04:48 AM
