Old 03-30-2013, 08:52 PM   #1
sd88supra
sd88supra is on a distinguished road
Default Super cheap '87 5spd turbo? What to look for?
I can pick one up for $700... of course, it looks like garbage. The interior will need to be completely redone (blue, yuck), as will a new paint job, get matching wheels and new tires, missing cylinder lock, cracked dash, etc., looks more like a track car. In addition, it needs to have the subframe rebuilt/replaced.
The good? I happen to have an '87 NA that I've been using for parts. Hence, I won't have to spend much on non-mechanical parts.
My concern is the engine - what should I look for (aside from it running smooth)? This will be my fourth MK3, but my first turbo. I knew what to look for on the 7MGE when I bought my second and third Supras, but I'm not sure on the 7MGTE. The car has 155k miles, so my guess is the headgasket had to have been redone (*crosses fingers*).
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
sd88supra is offline   Reply With Quote
Old 03-30-2013, 08:54 PM   #2
sd88supra
Question
I forgot to ask, could I run a diagnostic after driving it like I would on an NA?
Old 03-31-2013, 01:28 AM   #3
At that price and in that shape I wouldn't count on ANYTHING being "good". No, 155K doesn't mean the head gasket's ever been redone, some people got lucky and made it as far as 200K before it went. Do a compression check, check for contaminated coolant and oil. Yes, check for diagnostic codes after going for a drive. Don't plan on your N/A being a donor for anything drive train related... A lot of it just won't work.
Old 03-31-2013, 10:02 PM   #4
sd88supra
Default I bought it!
Well, I bought it. I got it with some aftermarket gauges and a turbo timer. I have yet to do a compression test, but it seems to run fairly smooth albeit a vacuum leak.
It will stay parked until I study the Haynes manual thoroughly. We'll see how far I go before I give up :P
Old 04-01-2013, 02:41 AM   #5
Haynes?
Haynes?!
Haynes?????!?!???!?!?!!
Toyota Service and Repair Manual (aka TSRM) for the MKIII Supra.... The ONLY way to go. http://www.cygnusx1.net/Supra/Library/TSRM/MK3/
Old 04-01-2013, 04:49 AM   #6
sd88supra
I should have specified both, actually. While the TSRM is best, I'm still a noob in many aspects which will require me to use the Haynes as a reference. The TSRM assumes some prior knowledge, while Haynes assumes you're a noob.
Old 04-03-2013, 12:33 PM   #7
MA70-3.0GT
MA70-3.0GT's Avatar
Just be aware that both TSRM & Haynes have some glaring omissions & errors in torque specs (the main one being the head bolts which are specced as 58lb/ft but should really be more like 75lb/ft IIRC)
Also if the Haynes is anything like all the others I've read as a kid learing my hobby (it will be, they never seem to change!) then it will have other errors that could potentially kill you or others (like the Austin Allegro one with backwards brake M/C seals ) so anything you're not sure of or is contradicted by the TSRM you're best checking up first before believing either one of them
FL: 92 sc300 2jzgte, single turbo, 5spd r154 trans, tt supra rear end, etc... CHEAP Evoforlife Buy/Sell Cars 0 10-16-2010 02:27 PM
Cheap Na to turbo swap supraman121 MKIII Supra 0 12-07-2006 08:03 AM
