Old 03-24-2013, 09:26 AM   #1
Bill Vun
Bill Vun is on a distinguished road
Default Power Steering Problem
Hi
I'm a newbie to posting threads at this site but I've been reading threads for a long time.
I have a 1989 (build date) Supra, which I just got repaired for a blown head gasket. They machined the head and relaced the head gasket and I've had no problems with that.
My problem is that I'm finding my steering has become a lot heavier than before I put it in for repair. I have asked the repairer if they have modified the power steering however they said they haven't touched it.
I have checked the power steering fluid levels as well as have a basic look at the power steering lines to see if anything is leaking but all seems to be fine.
Not sure where else to look and would be interested in any possible thoughts or soultions to my problem.
Thanks in advance
Regards,
Bill
P.S I have owned the car since brand new and this is the only major problem I have had with it apart from a few battery problems.
Bill Vun is offline   Reply With Quote
Old 03-24-2013, 10:11 AM   #2
interested!
Question Power Steering Problems
Hi! , I remember there is a wiring loom connected to the steering rack , has this been disconnected? - easily lost in the cluttered engine bay.
Old 03-24-2013, 05:30 PM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Is it difficult to turn the wheel regardless of RPM, or is it only difficult at idle? If only at idle/low RPM, check that the vacuum line running from the accordion hose (after the AFM) to the power steering pump is attached. I've found that tends to be overlooked during reassembly of the intake piping.
Old 03-25-2013, 12:31 AM   #4
MA70-3.0GT
MA70-3.0GT's Avatar
As the above say, there is a vac line & a wiring plug that could be the cause. I'd favour the wiring for the speed sensitive power steering being left off (I did this once just to see what difference it made & it made the low speed steering heavier) but it's worth checking both.
Old 03-25-2013, 01:14 PM   #5
interested!
Smile Power Steering -problems
Hi! On my 7MGTE , this flexible small black hose is under and attaches to - the large hose at the Turbo intake -attaches to a right angled pipe -- easily overlooked , nearly forgotten this several times .
Old 04-07-2013, 09:30 AM   #6
Bill Vun
Hi all,
Apologies for taking so long to reply but thanks for the advice. I followed the trail of the wire and found it wasn't plugged in. When I plugged it in she worked a treat.
Thanks for your help.
Regards,
Bill.
Old 04-07-2013, 10:26 AM   #7
interested!
Smile Power Steering Problems
Hi Bill , The beauty of this forum are the variety of replies and possible cures for problems , very pleased that you found an answer and cured the power steering problem by reconnecting the loom . Question? did the repairers torque the head to the higher limit as recommended by this forum ? , retorqued mine ( 7MGTE ) to 75 ft lbs after 500 miles . Happy motoring .
???? power steering problem ??? help 1jsupra MKIII Supra 6 04-05-2012 08:59 PM
Power steering hose problem? supradestro MKIII Supra 10 08-17-2011 03:55 AM
Power steering problem chinesedawn MKIII Supra 0 02-14-2010 11:20 PM
Power steering problem JOEYP3RD Non-Generation Specific Questions 1 06-05-2009 05:19 AM
power steering problem 3.0trd MKIII Supra 12 06-24-2008 01:17 PM
