Old 04-22-2013, 12:35 AM   #1
EricJ1987
EricJ1987's Avatar
EricJ1987 is on a distinguished road
Default Newbie needs some 7m-gte engine help please
I recently got my hands on a '92 Supra N/A with a 7m-gte swap and a bunch of parts in boxes...my question is, how do I find out what year my engine is? Like where do I look for the casting numbers? Any help is very appreciated and thank you in advance.
-Eric
EricJ1987 is offline   Reply With Quote
Old 04-23-2013, 04:11 AM   #2
There is no way to determine the year. The best you can do is check to see which generation it is by looking at the engine harness/ECU connectors. If they're yellow it's pre89, if grey 89 or later, if it's mixed then it's very early 89.
Old 04-23-2013, 04:04 PM   #3
MA70-3.0GT
MA70-3.0GT's Avatar
I suppose you could check the manufacture date codes on some of the parts if you really wanted to (cam position sensor cover, coils & cover, cambelt cover etc), might not be all original parts but if you check a few and get some that tally you could get a fair idea of when it was built?
Old 04-23-2013, 07:41 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
Not even Toyota can identify the YOM from the engine number. I did read a post some years ago about the block external casting design changing throughout the years. Something to do with the webbing pattern on the outside.
Old 04-28-2013, 12:07 AM   #5
EricJ1987
EricJ1987's Avatar
Thank you guys for the help
Newbie Engine overhaul????need some input and advice please dieseltech24179 MKIII Supra 1 11-15-2008 02:23 AM
