Old 04-28-2013, 10:29 PM   #1
Bloody Ben
Bloody Ben is on a distinguished road
Default Damn power windows
Replaced both window switches, cleaned contacts and passenger motor works if hot wired directly. But passenger window will only go down with switch and the only way to hot wire it is beyond the last connector right off the motor. any further down the line and i can't get enough power to make it go up. do i just need to eliminate the two wire connector between the motor and switch or do you ave any other ideas?
Bloody Ben is offline   Reply With Quote
power windows on mk3 supra (89) aaronced MKIII Supra 3 11-25-2009 10:41 PM
Help needed in first pass at improved appearance finaltable Exterior , Interior, and Detailing 1 06-29-2008 06:34 AM
Power Windows are so sloooooowwwwwa! GTE89 MKIII Supra 6 12-12-2006 06:44 AM
Ghetto is a good seller ARZ Buyer/Seller ratings 0 11-15-2006 11:58 PM
power windows Tortilla MKIII Supra 5 01-22-2006 02:07 AM
