#1 |
hi...i am new to the forums and in the process of buying an 89 supra non-turbo... i have some quick Q's
is the non-turbo a true dual exhaust? is the non-turbo the same engine as the turbo? (besides the obvious differences... intercooler... diff computer... etc...) does anyone know if a super charger is made for the non-turbo? and does anyone make a CAI for it? thats all... for now...i may have some more later... as noobs always do!! |
#2 |
no supra has a true dual exhaust
91 N/A automatic supra;K&N FIPK;2.5" custom exhaust;no cat;pacesetter header;eibach springs;tokico "blues";MKIV TT rims |
#3 |
unless its custom anyway
#4 |
SP58GT
no dual exhaust...luckily...a supercharger is made for the n/a supra..its somewhere on teh forum...from a previous post, and they do make CAI for the n/a or you could make a custom CAI...i know k&n lets you mix and match filters and pipes...the major difference between teh nonturbo and turbo motor is that the nonturbo has a higher compression...so teh internals are different, teh turbo is built to handle boost, the nonturbo isnt...so if you decide to put a turbo into an n/a you will have to think about getting low compression pistons
Now: Saving for an MKIV Broken Rides: (Sold) 91 supra turbo 5speed with a 1jzgte motor 421whp 400(399) ft*lbs of torque on tap @ 15 psi "Always outnumbered, never outgunned." |
other supra forums?? | TITAN DOHC V8 | Non-Generation Specific Questions | 3 | 08-28-2007 01:53 AM |
New here, quick question on possible lean issue | adamsbomb | MKIII Supra | 6 | 02-13-2007 04:42 PM |
Quick release hub adapter | 88Supraboy | Non-Generation Specific Questions | 0 | 03-02-2006 01:55 PM |
Other popular MK3 forums? | baller | MKIII Supra | 1 | 02-14-2006 10:22 PM |
