Old 05-02-2013, 07:14 PM   #1
sd88supra
Default Car won't start! (electrical)
All of the sudden, my '87 turbo won't start. The engine turns. There's power to everything, but it's not being distributed. I had the cps checked out and it's ok, so its wiring iis probably the culprit.
Is there anywhere on the TSRM for troubleshooting that particular electrical portion of the car?
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
Old 05-03-2013, 12:53 AM   #2
make sure your getitng spark and fuel.
can find all your info here:
http://www.cygnusx1.net/Supra/Librar...ection=FI&P=10
make sure your looking at things for the 7mgte when using the manual as the sensors are not the same.
for cps:
http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=20
check your timing, MABY its just way off and time for a new belt.
Old 05-08-2013, 02:53 AM   #3
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Check fuses espcially the EFI fuse. After that take out the front spark plug and ground the body of the plug while someone cranks the engine to check for spark jumping at the electrode (wear rubber gloves). The service manual has a diagnostic scheme to follow. The fuel pump can be checked for flow by jumpering Fp and B+ with a thin wire or paper clip in the diagnostic block with the ignition on. You sholud hear fuel flowing near the pressure regulator on the fuel rail. Check for error codes from the car's computer.
car suddenly wont start - never ran great anyway, esp. cold, now cranks, but won't st rjSupra MKIII Supra 41 03-21-2014 05:27 PM
Roll start but no key start. Need help Mrow MKIV Supra 1 09-11-2011 06:11 PM
87 non turbo wont start, need some advice...please. HotRodV6 MKIII Supra 3 09-02-2010 07:29 AM
