Old 05-07-2013, 02:13 AM   #1
Killa B
Killa B's Avatar
Killa B is on a distinguished road
Default Overdrive Indicator Flashing
So last night I blew out what I believe is a coolant return hose the little 90 degree one on the back side of the head just above the EGR Plate. after the hose blew out my O/D OFF indicator started flashing while the overdrive was on. It doesn't flash at all when the vehicle isn't moving weather its in park or drive. And it stays lit when the overdrive is actually off. The over drive its self still functions properly so my guess is there is a connector around the bell housing that got wet or I might have accidentally disconnected something. Have any ideas?
1989 na turbo supra ~ 3ARacing exhaust 2.5" pipe no resinator, sports package
Killa B is offline   Reply With Quote
Old 05-07-2013, 05:21 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
A flashing "O/D" light is an indication of an auto transmission trouble code. I don't remember the exact procedure on how to check it, but it should be in the TSRM, as well as a description of said codes
Old 05-07-2013, 05:11 PM   #3
Killa B
Killa B's Avatar
okay thanks, do you know if there are muliple codes for a flashing O/D light? I dont have a code reader but i can look up the tsrm in my manuals and see if anything pops up about the O/D light.
Old 05-08-2013, 12:20 AM   #4
http://www.cygnusx1.net/supra/Librar...ection=AT&P=13
Old 05-08-2013, 12:35 AM   #5
Killa B
Killa B's Avatar
wow okay there flash codes haha sorry bout that im either getting a 11 or 22 from what I looked up 11 is the coolant temp sensor and a 22 is the ecu? since there is no obvious problem mechanically should I just reset the ecu?
Old 05-08-2013, 05:05 AM   #6
Try again.... those aren't transmission diagnostic codes. Did you follow the link I posted?
As for the code 11 and/or 22: What good will it do to ignore the ECU codes? Something IS ovbiously wrong or they wouldn't be present. You may reset them to see if they're old codes for things which may have been fixed in the past but it's not too likely.
Gauge cluster, overdrive, power everything no worky? Cyto MKIII Supra 5 06-20-2012 04:37 PM
overdrive doesn't work kadinz MKIII Supra 4 06-14-2010 10:25 PM
Overdrive off light stays on scaggsj MKIII Supra 3 08-06-2009 01:51 PM
ECT, Overdrive 92supra MKIII Supra 5 08-30-2005 05:04 PM
automatic overdrive petewren MKIII Supra 3 05-18-2005 02:16 PM
