Old 05-23-2013, 02:54 AM   #1
Thunderbunny52
Thunderbunny52 is on a distinguished road
Default 1986.5 Supra 7mge
Just a little advice to any who may encounter this same problem!Your car has no spark and will not fire> The logical conclusion would be to check the coil and ignitor; but before attempting to buy this $500.00 igniter, unplug the wire going into the distributor and do a resistance check of the pick-up coil module. You should read between 160-180ohms between all three terminals if it is good. Any thing less replace The distributor! Unfortunately Toyota does not carry just the pick-up coils. Distributors are available online for about $150.00. Also check the blue and red wire going to the distributor ; the should be 12v if the igniter is good with the key in the on position.
Thunderbunny52 is offline   Reply With Quote
Buying a 1986.5 Supra youkilledkennedy Non-Generation Specific Questions 8 03-31-2015 05:02 PM
Newbie here w/ a 1986.5 Supra! vai2iant MKIII Supra 1 01-23-2011 07:22 AM
1988 supra 7mge engine blown what to do? 88supra7mge MKIII Supra 6 08-23-2010 05:22 PM
1986.5 Toyota Supra Nppn Turbo- New Turbo Help ! DarkRaiderz MKIII Supra 6 12-27-2005 09:04 PM
