Old 10-12-2005, 04:24 AM   #1
GreenChevelleSS
GreenChevelleSS's Avatar
GreenChevelleSS is on a distinguished road
Default Gasket above the plugs....
My gasket that is above the spark plugs is cracked and coming apart. What is this and where can I get another one? Its where the top of the plug wires seal to the head.... whatever....
1990 Toyota Supra Turbo 7M-GTE
1970 Chevrolet Chevelle SS 396
1996 Chevrolet Silverado Z71
www.cardomain.com/id/3115ultima
GreenChevelleSS is offline   Reply With Quote
Old 10-12-2005, 04:31 AM   #2
joel w
joel w's Avatar
yes, as far as i can tell it just holds the spark plug boot firmly inplace and has some stand offs inplace to support the plug wires. i seem to recall it being very hard to get the large allen "nuts" loose to remove and install the new gasket.
Old 10-12-2005, 04:48 AM   #3
GreenChevelleSS
Mines off I just need a new one, any idea on where to get one?
Old 10-12-2005, 06:08 AM   #4
joel w
joel w's Avatar
Wink
i think its a dealer gasket only? . in fact i think its the only gasket that was not included in my head set? but its been s few beers , i mean years... hehehe
Old 10-12-2005, 02:26 PM   #5
rnoswal
rnoswal's Avatar
In my service manual, it is called a cylinder head cover, but they also call the valve covers a cylinder head cover. It is just for keeping the alignment of the plug boot straight over the spark plug. The part could be sand blasted and then powder coated to look really nice, well what little you can see of it anyway. It seems that there is some sort of covering on that part and it peels off over time and with the heat. I have never seen one in a gasket set, but I have yet to find the 2 donut seals that go between the exhaust manifold and the double down pipe for my N/A. I get the big one that goes on the cat converter, I had always wondered what that one was for until I replaced my converter and saw the gasket there.
Oh well...........
Russ
Old 10-13-2005, 04:12 AM   #6
mrnickleye
mrnickleye's Avatar
It called the #3 valve cover gasket byt my toyota dealer. Cost $35. Dealer only part. 1 day order. It is there to keep debri and water from getting down around the spark plugs.
The 14mm allen head bolts come off easy enough. If you don't have the socket, you can make a tool with a 14mm head bolt and 2 nuts. Just put the 2 nuts onto the end of the bolt and 'lock' them together (double-nut), then put the 'head' into the allen bolt and use a box end wrench on the lower nut to unscrew the allen bolts.
Going back on, they just need to be tight, not really 'torqued', as they only hold the gasket in place.
Old 10-13-2005, 04:16 AM   #7
GreenChevelleSS
Do they require any type of sealant on the threads?
Old 10-13-2005, 04:28 AM   #8
mrnickleye
mrnickleye's Avatar
NO sealant needed.
Old 10-13-2005, 05:05 AM   #9
joel w
joel w's Avatar
id use a dab of anti-sieze when you put it back together. on all the threads for that matter. those allen nuts were really stuck in there.
Help! LOTS of oil on top of spark plugs trevor217 MKIII Supra 5 12-17-2008 07:19 PM
head gasket suprabahamut Non-Generation Specific Questions 1 05-04-2007 04:13 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
gasket help hangsupra MKIII Supra 14 01-28-2007 05:35 PM
