My gasket that is above the spark plugs is cracked and coming apart. What is this and where can I get another one? Its where the top of the plug wires seal to the head.... whatever....
1990 Toyota Supra Turbo 7M-GTE 1970 Chevrolet Chevelle SS 396 1996 Chevrolet Silverado Z71 www.cardomain.com/id/3115ultima ![]() |
yes, as far as i can tell it just holds the spark plug boot firmly inplace and has some stand offs inplace to support the plug wires. i seem to recall it being very hard to get the large allen "nuts" loose to remove and install the new gasket.
Mines off I just need a new one, any idea on where to get one?
i think its a dealer gasket only? . in fact i think its the only gasket that was not included in my head set? but its been s few beers , i mean years... hehehe
![]() Last edited by joel williams; 10-12-2005 at 06:50 AM. |
In my service manual, it is called a cylinder head cover, but they also call the valve covers a cylinder head cover. It is just for keeping the alignment of the plug boot straight over the spark plug. The part could be sand blasted and then powder coated to look really nice, well what little you can see of it anyway. It seems that there is some sort of covering on that part and it peels off over time and with the heat. I have never seen one in a gasket set, but I have yet to find the 2 donut seals that go between the exhaust manifold and the double down pipe for my N/A. I get the big one that goes on the cat converter, I had always wondered what that one was for until I replaced my converter and saw the gasket there.
Oh well........... ![]() Russ |
#6 |
It called the #3 valve cover gasket byt my toyota dealer. Cost $35. Dealer only part. 1 day order. It is there to keep debri and water from getting down around the spark plugs.
The 14mm allen head bolts come off easy enough. If you don't have the socket, you can make a tool with a 14mm head bolt and 2 nuts. Just put the 2 nuts onto the end of the bolt and 'lock' them together (double-nut), then put the 'head' into the allen bolt and use a box end wrench on the lower nut to unscrew the allen bolts. Going back on, they just need to be tight, not really 'torqued', as they only hold the gasket in place. |
Help! LOTS of oil on top of spark plugs | trevor217 | MKIII Supra | 5 | 12-17-2008 07:19 PM |
Head Gasket replacement questions. | DavidLeClair584 | MKIII Supra | 1 | 06-09-2007 09:17 PM |
head gasket | suprabahamut | Non-Generation Specific Questions | 1 | 05-04-2007 04:13 AM |
1986.5 with blown Head Gasket - Removing Spark Plugs | unkymurch | Non-Generation Specific Questions | 10 | 03-02-2007 06:48 PM |
gasket help | hangsupra | MKIII Supra | 14 | 01-28-2007 05:35 PM |
