Old 11-14-2013, 01:34 AM   #11
It's a bypass valve for the heater core. MOST of the time (except for when the AC is set on HI and when the car is warming up) it's open and allows coolant to flow through the heater core. Bypassing it will just keep coolant running through the heater core even when the car is still warming up and when the AC is set on HI. You probably won't notice a big difference except that it might take your car another minute or two longer to warm up.
Old 11-17-2013, 02:09 PM   #12
Life is Supra
Life is Supra is on a distinguished road
Thank u very much for the info and can u post some pictures w/bypassed heater valve just for to be sure
Life is Supra is offline   Reply With Quote
Won't suck the water from overflow illusive38 MKIII Supra 7 05-24-2012 09:19 AM
water circulation problem subjated MKIII Supra 3 06-07-2011 08:20 PM
water in the hatch problem drod23 MKIII Supra 4 03-01-2011 06:37 PM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
