Old 06-26-2013, 12:51 PM   #1
Life is Supra
Life is Supra is on a distinguished road
Default Water valve problem
I have a problem with water valve leaking on a lever.Must I replace it or have a way to bridge it?
Life is Supra is offline   Reply With Quote
Old 06-27-2013, 04:49 AM   #2
I'm not sure what part you're referring to. Could you post a picture?
Old 06-27-2013, 08:10 AM   #3
Life is Supra
or this one
Old 06-27-2013, 11:23 PM   #4
This may be what you're looking for: http://www.toyota-supra.info/forums/...resistors.html
Old 10-07-2013, 01:44 PM   #5
Life is Supra
this one on the second picture where the bolt is.I have a waterfall sound behind the dashboard and when I goes hard on her the temperature goes up and when I drive normaly it will drop.And like the coolant disappear after a one hour driveing.And also when I turn the heat on it blows cold air
Old 10-07-2013, 03:45 PM   #6
If the valve is leaking you could bypass it and give up having a heater or bypass it so that the heat is always on. I don't think either will make you very comfortable in the long run. I would try to find a used valve for replacement. The valves don't seen to fail very often, it's the connected VSV which controls it that usually fails.
Old 11-11-2013, 06:33 PM   #7
Life is Supra
Problem is I have a leaking on a lever where the bolt is.could u help,the engine is on the rebulit now,thanks
Old 11-13-2013, 01:45 AM   #8
http://www.cygnusx1.net/Supra/Librar...spx?F=8716&P=1
So the lower part of 87240, where the two hoses meet, is leaking?
If so then you just need to find a replacement. You can bypass that valve for the time being with a 90 degree pipe and your heat will work fine. Your air conditioning will also work with it bypassed but it won't get quite as cold.
Old 11-13-2013, 01:32 PM   #9
Life is Supra
yes betwen two hoses is plastic part or the valve with the lever on it with bolt there is the leak.So can I just remove it and put 90 degre hose for the time I find the replacment or must I replace it right away.
Old 11-13-2013, 01:36 PM   #10
Life is Supra
And sorry if I ask but what is the purpose of it
Won't suck the water from overflow illusive38 MKIII Supra 7 05-24-2012 09:19 AM
water circulation problem subjated MKIII Supra 3 06-07-2011 08:20 PM
water in the hatch problem drod23 MKIII Supra 4 03-01-2011 06:37 PM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
