Old 07-14-2013, 04:14 AM   #11
btwilson86
Super Moderator
btwilson86's Avatar
I believe (by process of elimination) that the injector resistor pack is the metal box in the engine bay on the driver side fender. However, if you're using the 89 harness and ecu 1) I don't believe that there will be a plug to connect the resistor pack to and 2) you shouldn't need the resistor pack anyway using the injectors from the 89.
So which color injectors do you have; Yellow or Green?
After fixing the code 24, does your car run any better? Can you get it to idle without the exhaust manifold glowing red?
As for the code 52, does your A/C have freon in it? If not, that code has been triggered in my 88 I used to have for that very reason. I fixed it by placing a paperclip between the terminals of the low pressure switch, and again on the high pressure switch on the A/C system. This bypasses both of the switches, and acts like everything is ok in the A/C system. Be sure to not press the A/C button on the climate control unit with these jumpers in place, as this may damage your A/C compressor.
Old 07-17-2013, 11:02 PM   #12
joemccaleb
joemccaleb is on a distinguished road
im running green top injectors at this time. i do have a empty plug near where a possible resistor pack may go. it does seem to run a little better with the new mass air flow sensor, but still nothing like it did in the 88. I have eliminated ISC. open for suggestions!! am I going to have to swap wiring harness??? im sure hoping not, but at this point beginning to wonder what to do
joemccaleb is offline   Reply With Quote
Old 07-17-2013, 11:04 PM   #13
joemccaleb
it will idle but only at 500rpm. the exhaust manifold isnt turning red anymore thank god. no ac unit in place so code 51 can stay there
Old 07-21-2013, 06:46 PM   #14
Can't set timing with codes present.... (I think that means ANY codes). Properly deleted you will have no codes from removing the A/C.
Old 08-01-2013, 08:11 PM   #15
joemccaleb
so im open for suggestions. do i need to swap wiring harness distrubutor and injectors or what?? please someone help i need a supra
Old 08-02-2013, 06:34 PM   #16
Did you get rid of the code 51?
I'd forget the harness, I'm pretty sure the impedance difference is enough that if the injectors and ignition were mismatched the would either not run or the injectors would burn up. If you tried running a pre89 wireharness with no injector resistor pack it wouldn't run either as there would be a break in the circuit. Does the ECU have grey plugs or yellow?
When you say you eliminated the ISCV does that mean you deleted it or just diagnosed it and are certain it's not suspect?
I haven't been following this thread so I need to go over everything before I can offer anything else.
Old 08-27-2013, 09:59 PM   #17
joemccaleb
just diagnosed the iscv working fine. I cant even get any real mechanics to touch it!!! I so dont want to giveup on this car, its not my 88 targa top car I foolishly wrecked after 24 yrs of loyal service, but it did belong to a dear friend who commmited souicide and his parents gave me the car to get it out of their life. Im starting to think my old friend is haunting it. 4give the delay in my response I had to walk away from it for a few weeks. i have thrown nearly 1000bucks at it radiator fan etc. It must live somehow!! I have both ecu"s the 88 is yellow plugs the 89 grey. I have kept the totalled 88 for parts, not that its doing me anygood! My wife just doesnt get it she wants me to buy some gas mileage generic pos. I just want to wheel that 4wheel independant suspension down a curvy road. So any and I mean ANY Suggestions of what to try will be greatly appreciated id like to make her run again just to show these fools who dont know toyota engineering that they are wrong. DESPERATE IN TN. Thnx
Old 08-29-2013, 03:22 AM   #18
Ok, checklist time....
Code 51 - present or fixed?
Mechanical timing set properly - yes or no?
Injectors - yellow top or green top?
ECU - yellow plugs or grey?
ECU wiring harness plugs - yellow or grey?
Injector resistor pack - present or not?
Distributor - pre89 or 89+ (the pre89 model has a pigtail, the 89+ revision has the harness connector molded into the body)?
TPS properly calibrated - yes or no?
Any other error codes present?
These parts are not interchangeable... Toyota did a decent job at making the wiring stuff easy to follow... Grey plugs on harness + grey plug ECU + green injectors... Yellow plug harness + yellow plug ECU + yellow injectors + resistor pack (only present on the pre89 harness, if you don't have a spot for it you're running a GREY plug 89+ harness or you're looking in the wrong place). I wish that they did the same thing with the GE that the did with the GTE and changed the shape of the connectors instead of just the colors but really it should be pretty obvious if you've got the wrong color combo.
Tags
88 t0 89 swap
7mge hp increase info 907mge MKIII Supra 14 02-05-2011 03:03 AM
7mgte to 7mge conversion help wayzhack MKIII Supra 7 09-07-2010 08:22 PM
7MGE Head Swap 7MGTE87 MKIII Supra 3 03-27-2010 06:39 AM
7mge vs. 7mgte KNYFE MKIII Supra 3 09-27-2005 02:21 PM
