Old 07-07-2013, 05:57 PM   #1
joemccaleb
joemccaleb is on a distinguished road
Default 89 wont idle runs rough
someone help!!! 89 7mge womt idle runs rough and now the exhaust manifold is turning cherry red hot!! what the heck is going on?? please any help would be greatly appreciated
joemccaleb is offline   Reply With Quote
Old 07-08-2013, 02:39 AM   #2
Thunderbunny52
Thunderbunny52 is on a distinguished road
Wink
More than likely the catalitic converter is stoped up. It is flanged so you can remove it and knock the insides out with a large screwdriver or piece of pipe; untill you can make a permanent repair with a replacement. They run about $150.00on ebay.
Thunderbunny52 is offline   Reply With Quote
Old 07-11-2013, 10:33 PM   #3
yotabays
yotabays is on a distinguished road
Default coil pack
Sounds like you have a bad coil. The cylinders that are not firing are dumping raw fuel into your cats. Will not idle because its misfiring. Had the same problem on a SC400.
yotabays is offline   Reply With Quote
Old 07-12-2013, 11:21 AM   #4
interested!
Question 89 wont idle runs rough
Hi! , have you checked the timing ? , red exhaust manifold usually mean a retarded ignition. ( late firing - fuel still burning as it enters the manifold ).
I think this is your first check to carry out .
Old 07-13-2013, 12:39 AM   #5
joemccaleb
I have checked timing. set base time but still retarted swapped 88 engine to 89 body, injectors and distrubutor were different plugs so I used 89 dist. and injectors
Old 07-13-2013, 12:52 AM   #6
joemccaleb
88 engine 89 body and harness. injectors and dist. have different plugs at harness so I used those 2 parts now timing is retarted even with jumper wire in place still seems to advance and retard????!!! ohhh this one is got me wondering if the dist. is that different?? diag. port gives codes 24 and 51 air temp and a/c. why will it show a code and not lock out ecu from controlling timing??
Rough idle on warm start up (20 minutes), 87 7MGTE Bru MKIII Supra 10 05-11-2012 12:27 AM
87 N/A ...rough idle ochowdero MKIII Supra 2 09-09-2010 06:16 AM
87 Turbo runs rough supraman7 MKIII Supra 2 07-30-2010 02:46 PM
Rough Idle????? ZauggIt1 MKIII Supra 2 11-11-2006 08:50 PM
1982 supra runs really rough when cold tylertatum Non-Generation Specific Questions 0 10-04-2005 08:01 PM
