Old 08-18-2013, 12:27 AM   #1
chickeneater
chickeneater is on a distinguished road
Default Heater control panel
I would like to remove my heater control panel (the thing that controls the HVAC system position, blower speed, etc.) but I can't make sense of the harness. I would ideally like to have a multistage switch that I hook up the ground and it simply connects different pins to control the blower speed (I don't have any of the other things hooked up except the blower anyway).
The problem is I can't figure out how the blower is actually powered. I can easily switch what MODE the blower is in (hi, mid, low, off) but I can't get it to turn on. What do I have to connect to get the blower to actually turn on?
Thanks!
chickeneater is offline   Reply With Quote
Jdm 1993.5 supra N/a heater control help j.orr MKIV Supra 4 05-20-2010 04:51 PM
Cruise control Rob1 MKIII Supra 0 05-18-2010 04:37 PM
Heater Question 87 Supra lobosupra MKIII Supra 3 12-11-2008 01:51 PM
Heater Control Valve-can you still buy these new? colin172 MKIII Supra 2 04-19-2007 03:49 AM
Heater By-Passing...Your Thoughts mrnickleye Non-Generation Specific Questions 2 05-03-2006 03:06 PM
