Old 11-09-2013, 10:50 PM   #11
7MGTReeds
7MGTReeds is on a distinguished road
*UPDATE*
Got the new unit in yesterday and got it installed. unit works as advertised! definitely got a bad unit from the last guy i bought it from. i can definitely tell a difference from the build quality. the unit is heavier, the wire loom looks cleaner and the switches actually make a click when you turn them. and the knobs on the new unit ARE connected to black switches.
i wired it the way the directions tell you to for an 89+ 7mgte and it did not work. I ended up having to wire it up the way the 3sgte says to do it. RED is the way that didn't work and GREEN is how I have it wired on the below instructions:
current working setup is as follows:
Red wire - +B (black w/red stripe wire on ECU connector)
Black wire - Ground (anywhere to the chassis)
Yellow wire - IGF (Turquoise w/black stripe wire on ECU connector)
Green wire - NE (Blue wire on ECU connector)
White wire - E-Brake (white wire coming from E-Brake light switch)
I'd imagine it would go the same way for the 87-88 ECU just make sure you're tapping into the ignition and RPM signal wires (IGF and NE) respectively. 89+ 7MGTE guys, here is the way you wire this thing up! i hope this helps and works for anyone else who is trying to do this.
7MGTReeds is offline   Reply With Quote
Old 11-10-2013, 04:42 AM   #12
Thanks for posting. The pre89 and 89+ ECU connectors are quite different as far as both pinout and color code are concerned. '97-'88 would look like T-12 on that page but Y and G are reversed if Y = NE and G = IGf. R is correct for +B1.
EDIT: When in doubt refer to the manufacturer's diagram... http://www.cygnusx1.net/supra/Librar...aspx?S=FI&P=50 Confirms that the diagram they listed is not correct.
So, did you have the last unit correctly wired at any point? Just curious.
Old 11-10-2013, 04:02 PM   #13
7MGTReeds
Yeah I had it wired in the configuration I have now and it didn't even work. The lights flickered at the right times when the ignition was supposed to cut but didn't work
Old 11-10-2013, 07:11 PM   #14
Ok, thanks. Well, at least you've got it all running now. Did you have any luck returning the bogus unit?
Old 11-11-2013, 01:54 AM   #15
7MGTReeds
the issued me a full refund, no questions asked, and didn't even ask for the unit back. i offered to ship it back but they didn't even want it so i kept it haha!
mk2 speed limiter possum MKII Supra 0 05-05-2010 05:03 PM
Is this true? Fuse removal can change limiter jdbones Non-Generation Specific Questions 0 12-30-2007 10:31 AM
Rev limiter and Dyno curves carl johansson MKIII Supra 1 11-19-2007 06:21 PM
Speed limiter cut greddy defender old dude MKIII Supra 5 04-08-2007 07:48 PM
speed\cruise control limiter removal The_Black_Beast MKIII Supra 4 03-13-2006 10:20 PM
