Old 11-06-2013, 04:22 PM   #1
Killa B
Killa B's Avatar
Killa B is on a distinguished road
Default Spark advance
So I rebuilt my 89 N/A a while back the head was torqued wrong due to all-data listing for spec so the head warped and I had to get it machined again. Ever since the rebuild it was hard to get the spark advance just right and it became more difficult after the head was machined the second time. I don't know exactly what was taken off but someone had told me once a head is Machined the spark advance becomes a whe lot more precise to set perfectly I was wondering if anyone knew the best way to set it to the exact potion and yes I have replaced the rotor button and cap spark plugs and wires I'm running NGK laser platinum twin tip plugs now. Any help would be appreciated!! Thanks.
1989 na turbo supra ~ 3ARacing exhaust 2.5" pipe no resinator, sports package
Killa B is offline   Reply With Quote
Old 11-06-2013, 07:10 PM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Shaving the head does slightly decrease the distance between the cam gears and tge crank gear, which i believe could make it difficult to set your camshafts perfectly with the crankshact (due to the set length and number of teeth on the timing belt). If the underlying cause of your problem is the camshafts (specifically the exhaust cam) not lined up correctly with the crankshaft, a set of adjustable cam gears can fix that problem.
I do not know how much material needs to be removed to cause the gears to not line up.
Old 11-08-2013, 02:06 AM   #3
It takes a lot to offset the ignition advance any significant amount. I doubt that even if the head were shaved to Toyota's "max allowable" that you'd be more than a degree off. The mechanical timing of the valves would be offset but again not to any level that's going to cause any issues whatsoever.
Still no spark - started Ground Location B wayja MKIII Supra 9 07-02-2012 07:37 PM
7mgte no spark supra.7mgte MKIII Supra 26 03-20-2010 03:16 PM
87 non turbo drove then died now no spark newtosupras MKIII Supra 1 02-25-2010 07:10 AM
No spark issues DDBT MKII Supra 2 01-06-2009 07:08 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
