Old 11-17-2013, 01:41 AM   #1
skidrow
skidrow is on a distinguished road
Default ma70 7mgte feul relay??????
7mgte auto ma70 no power to fuel pump relay.it also has a alarm could it be fuel cutting.
skidrow is offline   Reply With Quote
Old 01-14-2014, 06:31 AM   #2
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Here is a link to the online MKIII manual. http://www.cygnusx1.net/Supra/Librar...spx?S=FI&P=108
Check the engine error codes and clear them by pulling the EFI fuse for a minute.
http://www.cygnusx1.net/Supra/Librar...ection=FI&P=23
Check that there is 12-14 volts at the battery. 10 volts or less means a dead cell.
Check the operation of the "main" fuel relay (its the round one in the fuse box behind the battery).
Check for any blown fueses like the EFI fuse or the 30 Amp square one. If necessary check the circuit opening relay located in pasingers side kick pannel. Its described in the manual. you will need a volt/ohm meter and some alligator end jumper wires.
88 7mgte auto major electrical prob Noel MKIII Supra 1 06-07-2013 02:56 PM
Where is the fan relay on an na supra? batmmannn MKIII Supra 2 06-19-2010 01:40 AM
Need help please. 7mgte Toyota1 MKIII Supra 4 05-22-2010 08:33 AM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
