Old 11-03-2013, 05:29 PM   #1
nyborg88
nyborg88 is on a distinguished road
Default Newbie question 1 / ?
Greetings all...into the turbo 88 fold...just bought a 157k a/t turbo...turns over great but no start...Do I just assume the fuel pump is done right off?...not hearing a click or hum back there?Car was in storage indoors for a few years...drop tank either way ya?
nyborg88 is offline   Reply With Quote
Old 11-04-2013, 12:58 PM   #2
interested!
Question Newbie question 1 / ?
Hi! , Welcome to the forum , firstly , have you done the usual checks ?
Lots of fresh fuel ? , have you got a spark ? , is the battery fully charged ? , are the spark plugs clean ? -not sooted up ? . are the plug leads good ?
So many factors to consider - also many threads on this subject to trawl through . If and when you get it started , please let the forum know , thanks .
Old 11-04-2013, 01:30 PM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Fuel pump circuit is easy to test, and there are 3 major components in that circuit that can stop fuel from entering the combustiin chamber: fuel pump, fuel pump relay, and fuel injector resistor pack. To test if fuel is reaching the fuel rail, grab a paper clip and pop the hood. Right behind the battery next to the fuse block is a little rectangle box that says "Diagnostics" on the lid. Go ahead and take the lid off and look at the underside, there should be a little label that tells you the name of each of the 15 pins in tbat box. Locate the 2 pins labeled B+ (for battery positive) and FP (for fuel pump) and place your paperclip in both of them, so that it functions as a jumper wire. Now, when you hop in the car and turn the key to on, you should hear fuel rushing through the fuel rail on the engine. If you do, the fuel pump and relay are good. If you do not hear anything, grab a multimeter and the online wiring diagram and start by testing the fuel pump relay and fuel pump.
Also, check for engine diagnostic codes. You can take that same paperclip and place it between pins TE1 and E1 in the diagnostics box. When you turn the key on, the CEL (chdck engine light) will flash a number of times to indicate a stored trouble code. There is a thread in the MKIII Supra FAQ forum that explains how to check codes further.
Old 11-04-2013, 06:20 PM   #4
nyborg88
Default fuel pump
Thanks much...looks like coil cover was off recently as well...will let you know how i make out...think i'll drop tank and drain fuel anyway...at least 5 yrs old.
Old 11-04-2013, 06:53 PM   #5
btwilson86
Super Moderator
btwilson86's Avatar
If you're just looking to drain the fuel, there is a plug on the bottom of the tank that you can remove with a 3/8 drive ratchet.
If you're looking to drop it to clean it out, you may want to consider doing that fuel pump anyway. If it was my project, I'd spend the money on a quality unit just because it is likely the stock pump in the tank and I would not want to have to repeat the whole process in the future.
Before you do anything, try starting it and check the codes and report back here so we can help with any other issues it may have.
Old 11-05-2013, 12:19 AM   #6
nyborg88
Default fuel pump
Have a walbro coming in..will do fuel filter as well
Newbie has a question JohnFurness MKIII Supra 7 04-02-2011 06:40 PM
Newbie Question.. RonnyPockets MKIII Supra 3 05-26-2009 07:22 PM
newbie with question bluefever MKIII Supra 6 07-28-2008 12:24 PM
Newbie Question - Just bought 87 Supra Turbo NJ87SupraT Non-Generation Specific Questions 11 07-14-2008 02:01 AM
Super Newbie Question About Air Filters AssassinSM MKIII Supra 5 09-06-2006 04:55 AM
