Old 01-01-2014, 07:23 PM   #1
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Default R-154 transmission mount adjusting bolt
What is the proper adjustment for that flat headed bolt that protrudes from the center of the transmission mount bracket? I guess its purpose is to limit the up motion travel of the transmission.
I had a look with the cross member support off (supporting the tranny with the jack) to inspect the rubber of the mount for tearing. I ended up tightening the big bolt up until I felt it touching the end of it travel. With the weight on it hangs down less than 1/2 an inch below the surface.
engine removal mizuboi MKIII Supra 11 06-10-2011 06:25 AM
Transmission rant, help! Need advice or anything, asap ochowdero MKIII Supra 117 04-11-2011 10:49 PM
Will the R154 Transmission bolt up to a 7M-GE Justablurr MKIII Supra 4 09-24-2010 01:12 AM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
Trans Mount Change mrnickleye Supra FAQ 0 02-20-2007 05:24 AM
