Old 01-03-2014, 03:49 PM   #1
nyborg88
nyborg88 is on a distinguished road
Default Fuel tank drain
Going to drop tank to change fuel pump....how hard can i reef on the drain plug before i damage the tank..had a regular 3/8 ratchet on it...no movement yet..do i add a piece of pipe?..any secrets to dropping the tank and saving the mounting brackets?....
nyborg88 is offline   Reply With Quote
Old 10-14-2019, 10:56 AM   #2
yale
yale is on a distinguished road
Well, this response is a few years late but I just dropped the tank on my 86.5. Had to undo the holding strap brackets from the frame at the front side of the tank. The adjustment nuts were rust-welded.
I siphoned as much fuel as possible out first.
Once the two bolts on each strap bracket were undone (actually very easy to reach and easy to turn after soaking in PB Blaster for 2 days) the tank dropped nicely. The goose neck filler came loose easily after a bit of back-and-forth movement.
I have since been able to get one of the adjustment nuts working but the other isn't going anywhere.
Waiting now on getting five rust holes repaired on the tank.
yale is offline   Reply With Quote
How to remove fuel pump from gas tank? Bolts rusted! trevor217 MKIII Supra 0 09-22-2010 10:09 PM
fuel problem?.... i think supraluver4life MKIII Supra 6 03-27-2010 06:19 AM
fuel problem?.... i think supraluver4life MKIII Supra 0 03-22-2010 08:20 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
question about fuel tank mad_dicer MKIII Supra 4 10-16-2006 11:21 PM
