Hi, I've read several threads on here about this exact problem. However, I haven't found a solution. I bought my '87 mk3 with a blown head gasket. I replaced the head gasket. The car won't start though. The engine cranks and cranks but no go. I have spark. I have fuel. I've replaced my spark plugs and wires. I've replaced my ECU. I've replaced my coil ignitor. I've checked the timing. Any suggestions? I'm sure I'm missing something. I'm just not sure what?
Make sure your ignition timing is set right. Sometimes it takes a little trial and error of pulling out the distributor and turning the gear to get it to the right range to fine tune the timing.
Thank you. I'll give that a try. I've done it before, but I may still be off the mark.
#4 | |
![]() Quote:
Thanks. I'll pull the plenum off and take a look. I hope I haven't missed something so simple as that.
#6 |
I had rthe same issue.
I tried the following which worked for me... a) Check ALL Earthing points b) Ignition timing needs to be correct or the engine wont start. It takes time but its worth it ... Let me know how it goes... |
#7 |
Bone Stock w Upgrades ;-)
Make sure that bundle of harness ground wires low down on the intake side of the manifold is tightened down otherwise you'll get weird things. I had mine hand tight and it was acting very squirrelly. When you install the cam position sensor or distributor follow the alignment method otherwise the timing will be off. The same goes for the camshafts and the crankshaft. They all need to be in time to work properly. The firing order is 1 5 3 6 2 4 on a distributor cap. The rotor cap will be pointing to 1 when installed properly and with 1 at the top of the compression stroke. The coil pack wire order from left to right is 1 6 3 4 2 5. Check for spark using a good spark plug held against a ground point while someone cranks the engine briefly. When you get it started and warmed up, jumper T1 to TE1 and set the timing with a timing light to 10deg BTDC at idle with the air conditioning off. You may want to check your fuel pressure to see if you have any. You can "hear" the fuel flowing at the rail by turning the ignition switch to the on position but not cranking and then jumper B+ to FP in the diagnostic block behind the fuse box. Mack sure all electrical plugs are plugged in. Lastly, if yours is a Turbo, you can wiggle the wires that go into the cam position sensor. I had one that was funny that way.
Here are links to the on line repair manual. valve timing http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=29 ignition timing http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=20 non turbo distributor http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=17 turbo cam position sensor http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=21 Last edited by Bru; 04-23-2015 at 07:24 AM. |
#8 |
by any chance you guys know where all the grounds are in the engine, cause I'm having the same problem i just wanna make sure I'm good.
