Old 05-14-2014, 11:01 PM   #1
86targatop
86targatop is on a distinguished road
Default karmen vortex possible issue...HELP!!
Hi I just bought the car about 2 weeks ago and it will turn over but she will not stay running unless I am holding the accelerator. WILL NOT IDLE!! And at full throttle will not very or exceed 2100rpms...any suggestions? Thanx in advance
86targatop is offline   Reply With Quote
Old 05-16-2014, 06:17 AM   #2
Have you checked for diagnostic codes? How to do so is covered in the MKIII FAQ section. As for Karman Vortex, that's the type of airflow meter used in the 7M-GTE (turbo models) whether you've got a GTE or a GE (which is all that was available until '87)... well, I'm not sure why you bring that up unless you've already diagnosed more than you've posted. A bad airflow meter (either type) could cause these symptoms, so could a bad knock sensor or several other things. Check the codes and post back with whatever you find.
Old 05-26-2014, 11:11 PM   #3
supraheelfan
supraheelfan's Avatar
supraheelfan is on a distinguished road
sorry to highjack this thread but this could help us both..
I have a code 31,43,& 52. I know the code 43 is no big issue cause I've almost fixed that but the 31 and 52 are a pain. What other makes/models can i get a afm from that will work with my 87 7mgte? B/C it's getting harder and harder to find an OEM AFM or even a decent used one.
The code 52 will not go away, however the car drives normal with the code one, meaning no lose of power etc...
Anyone who has never made a mistake has never tried anything new.
supraheelfan is offline   Reply With Quote
Old 05-27-2014, 08:12 PM   #4
supraheelfan
Which is better to do: go ahead and replace the OEM AFM. -OR- going to MAF T? Or is MAF T Pro the only way to go?
Old 05-28-2014, 02:30 PM   #5
Have you rewired the knock sensor with GOOD shielded wire? There's a writeup on it which is commonly linked to here or you can find it via Google. A code 52 doesn't mean the car will be in permanent limp mode, just that the ECU is detecting a significant failure in the knock detection system. If the code keeps coming back, don't ignore it.
Depending on your goals you may want to just look for a good, used Lexus AFM and use the electronics from that in your KVAFM's housing. The electronics are the same it's the housings that are different. This will have you up and running a lot quicker and for less cash. I like the MAFT Pro, but if you're not out to upgrade to S/D or can't find a Lex AFM either the MAF T or MAFT Gen II will be a simpler install and setup.
Old 05-30-2014, 09:31 PM   #6
supraheelfan
Thanks CRE
BTW, I did rewire the knock sensor by an import specialist 3 times and he swears the wiring is not the problem. The code 52 doesn't do what it normally would do, for instance the car has power through the entire powerband unless the code 31 comes up then it stalls go and stall again. I had the code 52 on the 7mgte for about 6 months and this doens't seem like a reg. code 52 causing all these problems. I've never had a code 31 and every since the code 31 it's been acting strange and I've yet to see this problem with a code 52. Plus the mech that fixed the knock sensor wiring did it very well with heat shield and extra care b/c I took it too him 3 times to fix the same problem (the code 52.)
starting issue? brian white MKIII Supra 7 08-11-2011 03:46 AM
control chip issue? redsupra MKIV Supra 2 05-23-2011 04:11 AM
vacuum lock issue? supraluver4life MKIII Supra 8 08-07-2010 10:54 PM
Wrist pin issue -- Was: Ris pen issue KeelanWiese MKIII Supra 3 02-13-2010 07:38 PM
Engine Run-on Issue gottadiesel MKIII Supra 1 04-02-2009 07:26 AM
