Old 06-04-2014, 08:01 PM   #1
carl johansson
carl johansson is on a distinguished road
Default Bolt dimensions trans to block?
Ok everyone, quick question. I am not at home now, but my project is: so i need some help on this question. I will be having 3 engines lined up on 3 different engine stands. so i need to pick up the correct bolts to mount the block to the stands. I am hoping someone knows the size and thread of those holes on the block. it may be something like 14 X 1.25? or 14 mm fine thread? but i don't know for sure, and I am 40 miles away.
any help would be appreciated
Last edited by carl johansson; 06-04-2014 at 08:02 PM. Reason: cant type worth sshhhipp
carl johansson is offline   Reply With Quote
Old 06-08-2014, 05:23 PM   #2
Might try calling the dealership to see if they know the size and pitch of part number 90119-10019. Or buy one and hit Lowes or HD for the rest. I think that's the only one you need for the stand.
Old 06-18-2014, 12:41 AM   #3
carl johansson
They turned out to be 14 X 1.25 pitch. fairly hard to find, had to go to 2 different fastener warehouses. needed a 70 & an 80 mmm - 2 of each.
HELP!: 7MGTE engine block info needed barton MKIII Supra 1 05-19-2010 05:54 PM
HELP!: 7MGTE engine block info needed barton MKIII Supra 6 04-14-2010 09:28 PM
decking block, reuse most parts. jvginpdx MKIII Supra 0 08-18-2009 07:03 PM
Trans Mount Change mrnickleye Supra FAQ 0 02-20-2007 05:24 AM
Broken Bolt scruffboy Non-Generation Specific Questions 6 10-31-2006 01:33 PM
