Old 08-13-2014, 07:08 PM   #1
Moosemkiii
Moosemkiii is on a distinguished road
Default mkiii starting problem please help
Hey there so I have a 1987 supra it's acting out in a weird way it will start and turn over but the odd time it will won't at all but the dash lights come on. I have replaced the starter I thought it could've been a dead spot which the old one did have and after I put the new one in it started first try but after I got home from my buddy's garage it acted out again but I tried it again today and started no problem but I know it's going to happen again any ideas
Moosemkiii is offline   Reply With Quote
Old 08-13-2014, 08:09 PM   #2
interested!
Question mkiii starting problem please help
Hi! , can you be a bit more specific , thanks .
Old 08-13-2014, 09:46 PM   #3
Moosemkiii
Hey sorry! ill try... what we have found out is that there is an electrical issue with starting the car for some reason there is not enough volts getting produced to hit the starter and turn over its not a battery issue im assuming it could be something with the wiring.
Old 08-14-2014, 09:00 AM   #4
interested!
Hi ! , No problem , Had the same trouble myself . Sometimes the starter would turn , sometimes not .
The answer is to modify the starter circuit by using the wire that goes to the starter to operate a heavy duty relay connected straight to the battery , the other side straight to the solenoid . This bypasses the flimsy wiring connections trying to operate the solenoid on the starter . Had absolutely no problems starting after fitting this mod . See an electrician to work out the wire dimensions .
Old 08-15-2014, 02:04 AM   #5
mirage83
It's a common problem with the MkIII, not enough voltage going to the starter through the ignition wiring. You can work around it as Interested says, but it's just that, a work-around. I've got the exact same issue in my '88, and have somewhat isolated it to the wiring near the ignition switch. Haven't locked it down yet, and am forced to use a HD relay and momentary switch to get by until I really figure it out.
Old 08-16-2014, 12:55 AM   #6
Moosemkiii
As of now your idea has worked! I appreciate the help alot i will keep you guys updated if anything else happens!
Old 08-16-2014, 09:11 AM   #7
interested!
Smile mkiii starting problem please help
Hi ! , Thanks for the feedback and glad it works . I got the idea from this forum someone posted many years ago . It's good to see it is still helping .
SO STUMPED! starting problem, help pls.. DawgB0 MKIII Supra 44 05-10-2012 05:26 PM
Really Bad weird starting problem? Raysupra MKIII Supra 7 12-04-2010 10:45 PM
'86 2.8L starting problem daveydogtx MKII Supra 1 11-20-2010 04:34 PM
MKIII Headlight Problem Supra275 Non-Generation Specific Questions 4 09-05-2008 09:06 PM
1986.5 Starting Problem supraman121 MKIII Supra 4 09-03-2006 03:51 AM
