#1 |
Ok here is my problem. i got to replace my right rear wheel bearing and come to find out that the bearing was grinding on the hub. Call up all the auto part stores and they dont even have one listed. Called Toyota and there is only one, in CA, for 400 bucks... so i just wasted 50 bucks on the bearing i just bought because i had to put my car back together. Is that some other hub or modification i can to to fix this because this is a major problem. i'm trying to rule out buying another supra for just the hub assembly because i do not have space for it and i got enough powertrain parts for 2 supras
Tags |
assembly, bearing, hub, wheel |
Thread Tools | |
Display Modes | |
88 Steering Wheel on 91 Supra | nick124 | MKIII Supra | 1 | 01-20-2013 06:36 PM |
replacing wheel stud | Rahnter | MKIV Supra | 3 | 12-10-2008 03:57 PM |
Having Trouble Removing the Steering Wheel | Chambers | MKIII Supra | 3 | 06-30-2008 01:03 AM |
Aftermarket steering wheel | RTZ | MKIII Supra | 10 | 02-07-2008 08:44 AM |
1991 Supra - Water in Rear Wheel Wells | unkymurch | Non-Generation Specific Questions | 7 | 03-02-2007 12:59 AM |
