Old 10-15-2005, 10:28 AM   #1
Prez420
Prez420 is on a distinguished road
Default boost controller
what boost controller do you guys n gals like? Im looking for one on EBay right now and there are so many! Im pretty sure I want an electric BC, but Ill go on your recommendations... thanx
Prez420
1987 Supra Turbo
www.blackrosetattoos.com
Prez420 is offline   Reply With Quote
Old 10-16-2005, 11:11 AM   #2
supraxe
supraxe's Avatar
supraxe is on a distinguished road
Greddy Profec B
ID:	44   Click image for larger version
ID:	45   Click image for larger version
German Tornado on Highway with 270 km/h
His name is Supra!!!!!!!!!No speedlimit!!!!!!!!!
supraxe is offline   Reply With Quote
Old 10-16-2005, 10:05 PM   #3
Prez420
thats the one you like? or is this 'the one' to have?
Prez420
1987 Supra Turbo
Old 10-17-2005, 02:38 AM   #4
supraxe
supraxe's Avatar
like and have.easy installation reliably nice design
Old 10-17-2005, 10:32 AM   #5
ddmcse
ddmcse's Avatar
Cool
i have the same one ..very nice works well
http://www.ddmcse.com/turbo/SANY2003.JPG
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 10-17-2005, 01:30 PM   #6
SupraMan1784
SP58GT
i have a boost controller on my hks fconv...that thing does everything... including turbo timer...dont need extra electronics...which is good
Now: Saving for an MKIV
Broken Rides:
Old 10-17-2005, 07:30 PM   #7
Prez420
I just picked up a used GReddy Profec B. thanx for the advice.
Prez420
1987 Supra Turbo
Old 10-17-2005, 07:48 PM   #8
joel w
joel w's Avatar
Default manual controller here...
i use a manual controller, just a modified air regulator and a vacume switch that lets me adjust the boost inside the cab , (Its not a boost valve/ bleeder valve.) i run a dual port actuator with a 7.5lbs spring. so when i turn off the switch it goes to 7.5 lbs of boost. (valet switch) then if i flip the switch its back to 12-14psi or whatever i have the dial set to..
nice for the rain and first and second gear launch.
Manual Boost Controller and Turbo timmer question ethan12510 MKIII Supra 5 02-20-2008 10:54 PM
manual boost controller!!!!!!! justin1642 MKIII Supra 6 01-16-2007 10:01 PM
Fuzzy logic boost controller... HELP. smurfmods MKIII Supra 7 10-08-2005 09:39 AM
ANY ONE EVERY USE A Apexi Boost Controller donutking MKIII Supra 1 10-07-2005 01:58 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
