Old 09-26-2014, 02:37 AM   #1
lwhit280
lwhit280 is on a distinguished road
Default this should be easy?
In the main fuse box,under the hood i have a space that say alt1.25-- went to toyota that said it was a fusible link i dont think so but cant verify it would someone look at their's and tell me if it's a wire or a 100amp relay u no the one's that look like a cube. It;s location is the left back side 2 relays set in front of it.
lwhit280 is offline   Reply With Quote
Old 09-27-2014, 05:57 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Yup, early MKIII's had a wire-style fusible link and the later years have the more modern fusible link cube like you can find at the parts store. If I remember correctly, the newer style is interchangeable with the old style so it shouldn't be too difficult to replace.
Old 09-27-2014, 10:35 PM   #3
lwhit280
thanks so much for your response.do you think that this shortin in and out would trigger my car, 87 supra turbo auto, to go into limp mode once the car got a little hot?
Old 09-28-2014, 01:10 PM   #4
Busted Knuckles
Busted Knuckles's Avatar
I replaced my wire-style fusible link with an 80A sealed-type. Direct fit. But I was chasing a charging problem. I doubt this wire would send your car into limp mode, it just handles to output from the alternator. Have you checked for codes yet? http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=23
Easy Fix for weather/molding strip !! 88Supraboy MKIII Supra 4 10-22-2011 08:49 PM
Any easy way to change spark plugs and #3 cyclinder cover? chinesedawn MKIII Supra 1 03-16-2010 01:30 AM
EASY Fix for PW failure NEOMKIII MKIII Supra 0 07-15-2009 09:44 PM
Easy Question, Does the MA70 have alot of production line changmeister88 MKIII Supra 1 03-13-2006 10:56 PM
Just got a 1989 Supra! Have an easy Question! V1P3R MKIII Supra 12 03-09-2006 02:26 AM
