Old 02-02-2015, 04:01 AM   #1
Jordanc
Jordanc is on a distinguished road
Unhappy 2jzge mk3 supra swap electrical issue
I recently bought a mk3 supra with a 2jzge swap(non vvti). the wiring to the distributor was ghetto(wires twisted together) and the wire to the engine coolant temp sender which comes from the wiring harness was twisted together. so i decided to slice the wires so there would be no bare wires. but me being a dumbass forgot to disconnect the neg battery terminal when splicing the wires. now when i connect the neg terminal the battery voltage drops around 2-3 volts. i replaced the distributor and checked for shorts and still nothing. could I have possibly fried the ecu?
Jordanc is offline   Reply With Quote
Tags
2jzge mk3 supra
Things to look out for in ENGINE SWAP 1992 Supra nonturbo jduvall24 MKIII Supra 18 09-24-2012 11:55 AM
Supra Electrical system tom917 MKIII Supra 1 12-27-2011 08:01 PM
94 Supra TT with idling and lost of power issue bayatt MKIV Supra 4 03-12-2010 01:29 PM
1986 Supra Issue Cameroonski MKIII Supra 12 01-08-2010 04:23 AM
2JZGE Swap....not 2JZ-GTE AlexSchuSupra MKIII Supra 1 10-31-2009 11:09 PM
