#11 |
Super Moderator
Yeah, I really doubt the turbo is bad as well. The seal I was talking about is internal to the turbo, and should be new with the rebuild. I don't know if its normal or not, but when I got my new-to-me 57 trim from Driftmotion, mine did leak a little oil into the compressor side (I poured oil in the CHRA to lube bearings and such before install). My understanding is this is normal, and turbos normally do seep a little oil into the cold side.
I had to tighten the $hit out of my silicone couplers, way tighter than I thought they should be, in order to stop the leaks I had
1989 7MGTE R154 Targa Top White Package w/Blue Interior Driftmotion 57trim CT26, Upgraded Intercooler, 2.25" Hard Pipes, 3" Turbo Back Exhaust with Test Pipe, HKS VPC w/GM 3 bar MAP sensor, APEXi S-AFC, Walbro 255lph fuel pump, ProSport EVO Series Boost / Fuel Pressure / AFR gauges, Lotek a Pillar Gauge Pod, HKS Type 0 Turbo Timer, Eibach Lowering Springs, Tokico Illumina II TEMS struts, custom powder coated Motegi Racing TrakLite wheels |
#12 |
Also, I am bewildered that oil is coming out of the bov that I had to put on with a snap ring. Maybe the pressure is too much at that spot and shooting out the place with less resistance? But if a pipe doesn't pop off then oil will come out somewhere even though I have been tightening the crap out of the metal clamps.
Anyone who has never made a mistake has never tried anything new. |
#13 |
I've never had any kind of problems like this until this freaking Driftmotion intercooler. So wtf, I don't want to go back to the stock intercooler but I just might have to in order to see what is happening. Any ideas?
#14 |
Yea I had NO idea what it was but you were right 100% of the time, I'm almost positive that there is a vacuum leak. There has to be a bit of unmetered air coming in. Now I'm going to make sure 100% I will make sure the piping is on air tight and will spend my time doing it one more time very tediously.
Thanks btWilson86. By the way Wilson, have u ever thought about go higher than 14psi?
Anyone who has never made a mistake has never tried anything new. Last edited by supraheelfan; 06-06-2015 at 06:37 AM. |
Thread Tools | |
Display Modes | |
1986 7MGE toyota supra Tune up | SupraMKII | MKII Supra | 0 | 04-09-2014 12:30 AM |
How to tune Apexi Safc?? | Conga1991 | MKIII Supra | 5 | 03-29-2011 01:44 AM |
Tune up on 7mge? | AlexSchuSupra | MKIII Supra | 2 | 03-03-2009 01:05 AM |
lookin for someone to tune a 88 supra | wingshooter92 | Non-Generation Specific Questions | 1 | 04-09-2007 05:38 PM |
Tune Up | scruffboy | Non-Generation Specific Questions | 7 | 01-21-2007 09:58 PM |
