#1 |
Bone Stock w Upgrades ;-)
It could be a bad plug connection. They get corroded too. Also they get pushed back in the plastic holder where they don't make contact. They are supposed to pinch against the prongs on the sensor. You could rig up a test harness with connectors that grip the prongs on the sensor (without touching each other and shorting) to bridge to the plug to see if the code goes away after clearing it first. There is also a test procedure using a Volt meter to probe the back of the plug at the ECU which is located behind the glove box.
Here is a link to the test procedure. http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=41 The plug back layout. http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=31 The voltage between THW and E2 should be O.1 to 1.0 Volts with the engine warmed up and the ignition switch in the on position (not running). Here is a test of the sensor itself. http://www.cygnusx1.net/Supra/Librar...spx?S=FI&P=113 Getting those square plugs with the spring clips off with out damaging them is always a chore. I use a pointy tip to pull the clip away on each side and carefully wiggle it loose. They snap on a lot easier with the clip back in its groove. Last edited by Bru; 04-22-2015 at 12:47 PM. |
#2 |
Thanks for the help, tested resistance and there wasn`t any so bought a sensor from toyota and passed it`s mot with emissions going down to 2.3.
Now i`m going to treat it to a nice fresh paint job. Cheers |
7mge hp increase info | 907mge | MKIII Supra | 14 | 02-05-2011 03:03 AM |
ABS Problem? | rasclaat_98 | MKIII Supra | 6 | 12-13-2010 09:53 PM |
speed sensor problem | nadircicek | Non-Generation Specific Questions | 8 | 10-09-2009 05:58 PM |
4runner 7MGE swap idle problem | grabber | MKIII Supra | 3 | 06-26-2008 11:45 PM |
7mge swap, electrical problem | 89n/aA/T-2turbo5spd | MKIII Supra | 5 | 08-15-2007 06:51 AM |
