Old 06-01-2015, 07:01 PM   #1
supraheelfan
supraheelfan's Avatar
supraheelfan is on a distinguished road
Default bought Drifhtmotion Intercooler
Every since the piping and intercooler has been installed it has oil coming out of the intercooler piping at an excessive amount and I even rebuilt my turbo with new seals and everything and it still leaks oil OUT of the intercooler piping and I would like some advice If there is any to give? Apparently the PCV piping could cause this? I'm going to get a catch can and according to DM if the catch can feels up then it's.... I forgot what he said it would be in that case, any help plzzz?
Anyone who has never made a mistake has never tried anything new.
supraheelfan is offline   Reply With Quote
Old 06-02-2015, 02:41 AM   #2
supraheelfan
Bump.................
Old 06-23-2015, 03:53 AM   #3
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Check to see if oil is seeping past the air flow meter into the air cleaner housing. That would indicate excessive blow by from the PVC system. A trace of oil at the inter-cooler inlet is normal. Be sure to use a dynamic (metal) seal in the turbo rebuild and not a carbon seal which will wear and leak. I use 20W-50 oil since I live in a hot state. Thicker oil tends to leak and be used less.
Intercooler setup Pic Request and Questions Semper_Fi MKIII Supra 8 07-29-2011 08:44 PM
Intercooler system choices? Need help to choose. Bl@ckh3art MKIV Supra 5 05-22-2011 01:59 AM
Next step: The Intercooler azerty Non-Generation Specific Questions 1 08-19-2009 09:22 AM
just bought a 1993 mkiv twin turbo, need help 1993suprawr MKIV Supra 66 10-10-2008 11:16 PM
Clean out your intercooler!! IHateHacks MKIII Supra 4 10-25-2007 08:33 AM
