Old 03-10-2015, 08:55 PM   #1
neonracr2
neonracr2 is on a distinguished road
Default Help!!! 7MGE problems after replacing headgasket
I'm hoping someone on here can give me an idea about what is going on with my 86.5 7MGE MKIII. To start, I bought the car with a blown headgasket in hopes of fixing it myself over the winter. Just for comparison purposes, I should say that even with the bad headgasket, the car would start right up, along with having throttle response. After getting the engine back together with the new gasket, the engine would start, idle extremely rough, and die almost instantly. After doing some investigation, I found that when I would turn the key to start it, I would get 10.8 volts to the fuel pump, but as soon as it would fire, the voltage would drop to 0 and that's when the car would idle rough and die. If I jumper the +b and fp connectors in the diagnostic port, the car will start and keep idling even though it is still very rough and extremely low. The problem now is that if you open the throttle at all, it will die instantly. Also, the engine gets hot really fast and almost smells like it's lean. Any thoughts on why I'm not seeing voltage under normal conditions or why it runs like this? The timing has been double checked.....it has a new TPS....no codes are showing up.....idk where to go from here. I'd appreciate the help. Thanks!
I forgot to mention......the engine does have an EGR delete as well.
neonracr2 is offline   Reply With Quote
Old 04-17-2015, 11:27 AM   #2
amebb
amebb is on a distinguished road
Have you tried checking the fuel pump relay and also have you made sure that there are no loose connections etc ...???
amebb is offline   Reply With Quote
Old 04-18-2015, 09:07 PM   #3
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Make sure the air flow meter is plugged in and that bundle of ground wires low down on the intake manifold is tight.
Check this response too.
http://www.toyota-supra.info/forums/...-but-wont.html
Old 07-18-2015, 04:14 AM   #4
fox74
fox74 is on a distinguished road
check the timing, sound like the timing belt was put on incorrectly, bad idle also can cause by vacuum hoses not connected or connected in a wrong place. if the air intake hose from the air cleaner is not connect to the air manifold the car starts, shakes and dies. good luck
fox74 is offline   Reply With Quote
Replacing a 7MGE with 7MGTE DakotaHyde MKIII Supra 6 10-04-2013 03:35 AM
88 supra still with problems 7MGE spunkenhimer MKIII Supra 17 02-24-2011 08:41 AM
Replacing the headgasket burton51m Show n Tell 4 07-12-2010 04:47 AM
7MGE ECU problems grabber MKIII Supra 2 06-10-2009 10:53 PM
