Old 10-16-2005, 05:38 PM   #1
boner1115
boner1115 is on a distinguished road
Default 1jzgtte in my 87 supra turbo
so i am thinking abotu buying a 1jzgtte motor and dropping it in to my 87 turbo supra, but i just want to know if it is a good idea, if anyone has done it, and how hard is the engine swap? also can i use the stock tranny and stock wireing harness.
i am gunan buy it from http://www.naganojapanese.com/jdm_1jzgtte.htm
boner1115 is offline   Reply With Quote
Old 10-17-2005, 12:08 PM   #2
1jz swap has been done quite a few times
it's 1jzgte as well... not two T's lol
you need an 89+ crossmember that has the round rubber mounts.. that'll tell you if you have the right crossmember as that is the only one that 1jzs will slot in to
you need engine loom + ecu... 1jzgte.us has the wiring info on converting from yours to 1jz
good luck with the swap
From Supra Non turbo to 1jzgtte Supra1987NonTurbo MKIII Supra 2 09-06-2007 01:03 AM
