Old 08-26-2015, 11:59 PM   #1
kjlemcke
kjlemcke is on a distinguished road
Default Only 3 psi of boost
Ok car was sitting for 5 years. There is no boost leak and I replaced all plugs and all vaccum hoses. Timing is on and I am hardly getting any boost at WOT. Can't really hear the turbo spool either. Car goes over 3k rpms and I can cruise at 80 but it takes forever to get there. Any suggestions would help. Been trying to figure this out for a while.
kjlemcke is offline   Reply With Quote
Old 09-15-2015, 09:39 PM   #2
S-mk3-B
S-mk3-B's Avatar
S-mk3-B is on a distinguished road
So first off are you determining the 3psi reading from the stock gauge, or an aftermarket one? So it looks like you checked all the basic diagnostics as leaks and vacuum hoses, you didn't mention it but double check your intercooler piping too, b/c that can add to your problem. And if all that checks out then I would probably suggest inspecting your exhaust pipings, cause if it's clogged/backed up at all then that could create back pressure. And after that it just might be a bad wastegate and etc... Hope this helps!
1989 Toyota Supra Turbo w/ Targa Top
White Exterior-Blue Interior
3" Blitz Catback Exhaust System
BIC Divorced Downpipe, Straight Pipe
Megan Track Coilovers
Apexi BOV, Turbo Timer, and Intake
Lexus Projector Fogs
Bride Low Max Replica
S-mk3-B is offline   Reply With Quote
boost controller ?'s sassan MKIII Supra 3 01-28-2012 05:37 AM
1jzgte no boost???????????????? MAP sensor? You have one? AlexSchuSupra MKIII Supra 3 06-17-2010 08:10 PM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
