Old 09-25-2015, 12:34 AM   #1
KevinJZA70
KevinJZA70 is on a distinguished road
Exclamation 1991 supra mk3 7mgte, sluggish.
I have a 1991 supra mk3 7mgte, car runs perfect when building boost, but anything before that, i would have to press the pedal down to get the car moving good. Any suggestions on how to make the car run better? Haven't changed spark plugs as yet.
KevinJZA70 is offline   Reply With Quote
Old 09-27-2015, 10:53 AM   #2
Busted Knuckles
Busted Knuckles's Avatar
Spark plugs and filters are where I would start. A compression test may not be a bad idea, either.
Old 10-07-2015, 07:50 PM   #3
S-mk3-B
S-mk3-B's Avatar
S-mk3-B is on a distinguished road
If you could be a little more descriptive that will help, so like is the idle good? How's the throttle response, is it sluggish overall?
1989 Toyota Supra Turbo w/ Targa Top
White Exterior-Blue Interior
3" Blitz Catback Exhaust System
BIC Divorced Downpipe, Straight Pipe
Megan Track Coilovers
Apexi BOV, Turbo Timer, and Intake
Lexus Projector Fogs
Bride Low Max Replica
S-mk3-B is offline   Reply With Quote
Old 10-07-2015, 11:59 PM   #4
KevinJZA70
Throttle response a little late, pedal has a little 'rusty' movement (maybe needs to be greased?) However, many people are saying change your sparks, throw in some injector cleaner and you should see a difference?
Old 10-25-2015, 01:26 AM   #5
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Check the Air Flow Meter and the Throttle Position Sensor adjustment. The Test procedure is in the on line service manual.
Never clean a Air Flow Meter with any solvent. Check for the 2 holes being plugged though.
Excess oil in the intake can ruin these.
http://www.cygnusx1.net/Supra/Librar...3/default.aspx
For Sale: 1991 Supra Turbo, Manual, $12,000 DCG Buy/Sell Cars 0 09-17-2012 03:18 PM
1991 7MGTE to 1987 7MGTE bobo4life MKIII Supra 17 08-07-2010 06:02 AM
