Old 02-07-2016, 02:15 AM   #1
NoMechanic
NoMechanic is on a distinguished road
Default Where did these two hoses go?
Hello everyone!
Hey I tore our my rack and pinion, pressure line and power steering pump for rebuild. While plugging away at this I found a couple things that didn't make sense to me. One air hose connected to a stud bolt off the manifold from the intake ducting. On my power steering pump there is a place for two air hoses, one of them didn't have anything connected to it. The last one was off of the thermostat housing, I had an air line there that went to nothing off of the bottom nipple?
I will add photos shortly, the forum is fighting with me on it right now
One moves, we all move
NoMechanic is offline   Reply With Quote
Old 02-07-2016, 02:25 AM   #2
NoMechanic
Sorry they are so small! I had to shrink them to less then 100kb to post
ID:	4955   Click image for larger version
ID:	4956   Click image for larger version
Old 02-08-2016, 03:33 AM   #3
NoMechanic
Has anyone had a chance to pop open their hood and take look over the weekend?
thanks!
Chris
Old 02-08-2016, 05:49 AM   #4
btwilson86
Super Moderator
btwilson86's Avatar
I think I can help sort this out, but I don't have any pics to show right now.
First, the vacuum line coming off your intake boot connects to that vacant port on the power steering pump. Make sure the other line on the power steering pump connects to a metal line a few inches from it (towards the timing cover), and that the metal line connects to the vacuum pipes under the intake manifold via another short rubber hose.
The part on your thermostat housing with 2 vacuum lines is called the "bi-metallic vacuum solenoid valve", or BVSV; these are almost always broken, so congrats on having one that's still intact! One of the nipples (doesn't matter which) should have a vacuum line going to the throttle body, before the throttle valve. The other nipple should have a line connected to the metal pipe on the air flow meter, and then another line from that pipe to the charcoal canister by the firewall. Connecting it to the air flow meter is not required, but it does help to keep the line away from the exhaust heat and tidies up the engine bay a little.
Hope these descriptions clear things up for you!
Old 02-09-2016, 05:56 AM   #5
NoMechanic
Just finished putting everything back together. Realized I forgot to pick up fluids! lol
How much Dex does the power steering system take on an empty system?
Old 02-09-2016, 05:58 AM   #6
NoMechanic
Hey I really appreciate this! No questions asked after reading this
Old 02-09-2016, 02:09 PM   #7
btwilson86
Super Moderator
btwilson86's Avatar
I'm not sure how much dex to put in a dry power steering system, I can't imagine it's much more than a quart though. Be sure to turn the wheel from lock to lock as you're filling it up, that should help any trapped air escape and improve it's performance
Old 02-10-2016, 10:04 PM   #8
yale
yale is on a distinguished road
Were your dust covers on the ends of the power steering rack still in good shape? I have one that is starting to crack and come apart. Can't find a listing for them at my local parts stores.
yale is offline   Reply With Quote
MK3 supra Hose Techniques silicon hoses Micahwc Shops & Part Reviews 8 12-09-2012 09:03 PM
AFPR vacuum hoses and an electrical problem Gunnar Non-Generation Specific Questions 0 06-11-2009 07:46 PM
Website for engine hoses? rinso MKIII Supra 7 05-02-2009 11:47 PM
Vacuum Hoses and Diagrams kewlcoconut MKIII FAQ 11 08-13-2007 01:41 AM
hoses? 89_supra_ MKIII Supra 4 12-25-2006 11:55 PM
