Old 03-07-2016, 11:03 AM   #1
t_rage
t_rage is on a distinguished road
Default Broken under bonnet Sensor
Hi, just got the my father's 1991 Supra out of the garage and got it running after about 4 years. Noticed that one of the sensors under bonnet had aged and broken off from the female engine side.
The engine is running OK but very rich and there is a slight backfiring that can be heard inside from the exhaust at idle.
Had a look on the site and can't find anything about a particular under bonnet sensor. Can anyone identify? Thanks.
https://drive.google.com/file/d/0B0Q...ew?usp=sharing
t_rage is offline   Reply With Quote
Old 03-12-2016, 12:36 AM   #2
mirage83
That's a really clean 7M you have there, but I can't tell for certain from your photo which sensor is broken. Here's a pic which might help you identify what you're looking for...
And another from a slightly different angle...
Old 03-14-2016, 09:53 AM   #3
t_rage
Ah thanks for the info. I can see it from the first pic labelled cold start injector time switch.
I guessing since we're past the worst if the winter and it starts fine I don't need this for immediately. Would anyone know if this would effect engine running once started? I'm guessing no.
Thanks all.
Old 03-16-2016, 01:31 AM   #4
mirage83
Nope. It's simply to provide additional fuel for a cold start, only time (to the best of my knowledge) it functions. I'd pick up a replacement from a junked car somewhere.
Tags
engine, sensor
AFM, MAF, MAP, sensor!?!? Revoker MKIII Supra 4 06-11-2014 09:11 AM
87 Turbo knock sensor issue supraman7 MKIII Supra 5 03-05-2010 07:44 PM
TPS Sensor and Auto Trans btwilson86 MKIII Supra 5 02-12-2008 07:31 PM
