Old 06-11-2016, 12:42 AM   #1
yale
yale is on a distinguished road
Default '87 MrkIII passenger inner tie rod
So I'm finally getting around to rebuilding the front end (could turn the tie rods by hand and the spindles clunked inside the ball joints). Driver's side tie rods were no issue. Passenger side however has this bracket that supports one end of a damper that is part of the steering rack.
The bracket will not clear the frame when trying to unscrew the inner tie rod. Looking at the new tie rod it appears the bracket screws onto the tie rod. Question is how do you get the old tie rod out without removing the steering rack? I'm almost to point of cutting a notch in the frame to allow just enough clearance for the bracket to spin with the tie rod as it comes off.
Couldn't find a reference in the Repair Manual (diagrams don't show the bracket and damper).
yale is offline   Reply With Quote
Old 06-23-2016, 04:42 PM   #2
yale
It appears that the bracket is essentially a large nut with the attachment for the steering damper/shock. It appears to have opposite threading from the inner tie rod so I guess the idea was that it would unscrew as you unscrew the inner tie rod from the steering rack.
I say "guess the idea" because I could find no way to get that bracket/nut loose. Wasn't able to find anything online about best practices and didn't get any feedback from this forum either. So I finally just cut the bracket off and unscrewed the inner tie from the steering rack. After securing the tie rod in my vise I was still unable to get it to turn.
Anyway, I put in the new tie rods, lower ball joints, upper control arms/ball joints and shocks. All is well and I can't tell any difference with there being no steering damper/shock in place.
Old 07-09-2016, 02:55 AM   #3
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Toyota dropped the damper after 1988. So evidently it doesn't make a big difference. What I did when I replaced my passenger side inner tie rod was to use a set of wrenches from Harbor Freight that got quite large in the mm selection to hold the rack and a very large Crescent wrench from Harbor Freight to remove an install that big flat threaded nut that holds on the support bracket for the damper shock. One thing to be careful of when you get down to the final tightening is to have the damper bracket pointing at the proper level so it's not cocked down and rubbing the splash pan later. It wants to slip and move when you get to the final tightening. I used red thread locker just to be on the safe side. 2 wrenches are necessary so that you don't put stress on the rack and pinon or you could damage it. Remember to bend over the new locking flat washer that comes with your new inner tie rod. It's called a claw washer to hold the inner tie rod from turning once its installed.
89 passenger headlight assembly? alarsen77 MKIII Supra 8 09-22-2010 12:35 PM
Passenger Door Wont Properly Lock SideWinderGX Car Audio and Alarms 2 03-03-2009 09:08 PM
Passenger Power Window Problems JanusDuo Non-Generation Specific Questions 1 12-17-2008 08:11 PM
passenger window wont open tone loc MKIII Supra 3 06-25-2007 10:37 AM
Passenger side window kewlcoconut MKIII Supra 1 03-29-2006 07:58 AM
